3M Marine High Strength Repair Filler - SailNet Community
 6Likes
post #1 of 13 Old 05-11-2013 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Does anyone have any experience/feedback using 3M Marine High Strength Repair Filler? It's a vinyl ester compound. I'm interested in using it for minor deck repairs ... some screw/through-bolt holes from removed hardware and and two openings, the largest being about 5" x 3". I want to fill and fair. Will paint the deck next season.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #2 of 13 Old 05-11-2013
tommays's Avatar
Re: 3M Marine High Strength Repair Filler
I have used system three silver tip quick fair filler Underwater for keel fairing and on deck for fairing dings and holes I have closed up
It mixes very easy and sands very easy And has held up for three years so far
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 13 Old 05-11-2013
Senior Moment Member
SloopJonB's Avatar
I haven't used it but every 3M product I've ever used has been the best of whatever it was. I would use that filler in a heartbeat.
It's a great company.
SloopJonB is offline
post #4 of 13 Old 05-11-2013
asdf38's Avatar
Yeah I pretty much second this. 3m makes a lot of great products. I'm really fond of their VHB structural 2 sided tape. Although I've probably used it in a few too many places.
That said it's also impossible to go wrong with west system epoxy which will also do the deck fill jobs you're talking about and a lot more. It's expensive to initially buy the 105, 205, filler, pumps, syringe etc but once you've got it you can do everything and epoxy is pretty much the best for all these types of jobs.
oysterman23 and Ritchard like this.
asdf38 is offline
post #5 of 13 Old 05-11-2013
No more curry buffets
Ritchard's Avatar
While I am also a 3M fan, I'm more an epoxy fan, especially below the waterline.
A nice epoxy mix with some 407 or 410 filler mixed to the needs of each particular job is as maleable as you need it for each such job, and sands wonderfully. The 410 is awfully light though, only for cosmetic repairs. 407 is someplace between cosmetic and structural.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #6 of 13 Old 05-13-2013
Old enough to know better
Yes, 3M makes good products, but I can't see filling a 3 inch by 5 inch hole without using some glass if you expect there to be any strength. I once upon a time filled holes about that size with bondo on a fender and it did not last long! Perhaps a screw hole, but not a big opening like 3X5. I think one good kick and it will pop out or at least crack.
jameswilson29 and SloopJonB like this.
miatapaul is offline
post #7 of 13 Old 05-13-2013
Senior Smart Aleck
jameswilson29's Avatar
I used fiberglass resin with colloidal silica to thicken for filling bolt holes. I agree with miatapaul about using glass and resin for structure and strength in any larger areas.
jameswilson29 is offline
post #8 of 13 Old 05-13-2013
asdf38's Avatar
Oh I agree. I missed that. Speaking of 3m Home Depot sells 3M glass cloth. $7 for 9ft sq. I'm not sure how that stacks up to marine prices but I'm guessing its less (for that small a size anyways).
asdf38 is offline
post #9 of 13 Old 05-13-2013
Senior Smart Aleck
Yes, Lowes sells 3M fiberglass resin and hardener and fiberglass cloth for quite a bit less than the marine sources.
[Erroneous smart aleck comments deleted by author.]
post #10 of 13 Old 05-13-2013
asdf38's Avatar
Originally Posted by jameswilson29 View Post
Yes, Lowes sells 3M epoxy and hardener and fiberglass cloth for quite a bit less than the marine sources.
Of course, it cannot possibly be as good as "marine" epoxy, hardener, and cloth, because it is half the price and does not have a picture of a boat on the label... (Plus, no one is making seemingly objective claims of incredibly superior tensile strength based on their own in-house testing.)
If they sold epoxy resin that would be news to me. I thought they had 3m polyester resin. Not that that's bad but epoxy is a notch better.
asdf38 is offline
Tags
fairing , fiberglass repair , filler , repair , vinyl ester
High Priced "Marine" Thermostats dbruce85 Gear & Maintenance 10 04-09-2013 08:56 PM
using 3M marine premium filler muskoka.sailor Gear & Maintenance 21 06-17-2012 12:35 PM
marine hand pump high and dry bornagainsailor General Discussion (sailing related) 4 06-28-2011 09:13 PM
Gary; Very good Marine Transmission repair referral NewsReader Mass Bay Sailors 0 06-27-2007 01:15 AM
NorCal Marine Sanitation Install/Repair? Fstbttms Gear & Maintenance 2 04-28-2007 12:26 AM
