Need to seal this up: - SailNet Community
 2Likes
post #1 of 14 Old 05-11-2013 Thread Starter
utchuckd's Avatar
Got a little fitting on the back of my boat that has a cable from the battery to the ob motor thru it. Problem is it's the cable and nothing else in the hole. It's above the water line, but with the large amounts of rain we've had this year I'm getting some water in my bilge (I hope this is the culprit).
From the outside:
From the inside:
Do they make a seal or boot or something for this? Should I replace it with another kind of fitting?
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #2 of 14 Old 05-11-2013
Re: Need to seal this up:
How about putting a clam shell cover over it to keep rain water out.
Jeanneau 54DS
Minnewaska is offline
post #3 of 14 Old 05-11-2013
asdf38's Avatar
Pull it out, redrill the hole and fill with epoxy.
Or stuff it full of sealant for a quick fix. But you should really do the above.
Edit: whoops, for some reason I thought the wire wasn't needed. Perko makes a decent 12v connector
That said unless tht hole is flush to the deck and in the path of a lot of runoff I doubt it can be contributing much to your bilge leaks. But look into it because it could be leaking into the core.
http://www.amazon.com/gp/aw/d/B00144B67C
asdf38 is offline
post #4 of 14 Old 05-11-2013
One of None
deniseO30's Avatar
waterproof plug and connector?
My last project!
deniseO30 is offline
post #5 of 14 Old 05-12-2013
c_witch's Avatar
Send a message via Yahoo to c_witch
Hi,
You can go with what Denise has suggested, although I would op for the style that has a screw on cap and plug assembly rather then the push on. The other option is a thru hull for wire. Basically a compression fitting with a rubber type of stopper that the wire passes thru and a cap that pushes it down and squeezes it tight around the wire. The wire must be round for it to work properly. If its for the gen or starter then I'd prolly op for the plug assembly and leave it connected to the OB when it is removed.
c_witch
c_witch is offline
post #6 of 14 Old 05-12-2013
SchockT's Avatar
What you are looking for is called a "cable gland", and they are available in all shapes and sizes.
I used something like this for cable penetrations on my boat:
Deck Gland
With smaller wires you may be able to get away with one like these:
Essentially the cable passes through a rubber "plug" which is compressed when the fitting is screwed together making a perfectly weatherproof seal.
chef2sail likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 14 Old 05-12-2013
c_witch's Avatar
Hi again,
Here are a couple of pics to demonstrate what I was talking about.
c_witch
c_witch is offline
post #8 of 14 Old 05-13-2013 Thread Starter
utchuckd's Avatar
Thanks all. It may or may not be where I'm getting water, but it looked like the best place to start.
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #9 of 14 Old 05-13-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
always a good place to start. If there is a hole, water will find it
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #10 of 14 Old 05-13-2013
Load Bearing Member
CarbonSink62's Avatar
Dock
I have a similar issue; the original 12VDC fitting for the OB was corroded, so last year I just made a longer pigtail for the motor and ran it through the scupper to the battery; bypassed the fitting completely.
This year, I'm already in the water with a new engine; the new cord is not round and I also have a transducer cable to run to the stern. My plan is:
!. Pull out the old fitting to open up the hole
@. Seal the inner surface of the hole with epoxy (probably not done when drilled)
#. Run both cables through the hole
$. Anchor the cables on the inside of the opening
%. Goop the opening up with black silicone (as neatly as possible)
That should kick the can down the road until next season. There are only so many hours available for commissioning.
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
UTS Hi seal connector? downeast450 Electrical Systems 2 03-08-2012 06:32 PM
How should I seal this hole? Perithead Gear & Maintenance 18 01-21-2012 01:43 AM
Tip on replacing a seal erps Gear & Maintenance 4 08-24-2009 07:11 AM
Dry-seal brak Gear & Maintenance 3 09-07-2007 05:55 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 12:03 PM
