Help pinpointing a leak - Page 4 - SailNet Community
 21Likes
post #31 of 88 Old 05-15-2013
asdf38's Avatar
Re: Help pinpointing a leak
Originally Posted by hillenme View Post
I I emailed the yard and asked if someone might take a glance at it before launching the boat, but I never heard anything back and went to down the next weekend to find my boat in the water.
Just noticed this...sounds like the boatyard communication standards I'm familiar with.
hillenme likes this.
asdf38 is offline
post #32 of 88 Old 05-15-2013
johnnyquest37's Avatar
Your leak is of great interest to me - I have something very similar going on. Just last weekend, I pinpointed a leak coming from inside a limber hole through a floor in much the same place as your leak. I used a snake camera to look in there and found a portion of uncovered glass mat where water is weeping through. Not much water - about 2 gallons accumulate in five days, but it is still disconcerting. I'm guessing at this point that either 1) my hull-keel joint needs rebedding or keel bolts need tightening; or 2) there is hole/crack in the gelcoat below the water line somewhere and this is where the water is migrating to, or 3) there is a leak above the waterline somewhere and this where the water is migrating to.
I do not want to seal over the exposed fiberglass I found in the limber hole for fear that the water will just migrate further along.
Anyway - appreciating this discussion so far.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #33 of 88 Old 05-15-2013 Thread Starter
hillenme's Avatar
Interesting, it does sound like what I'm dealing with. Your's is the second mention about a snake camera, I may have to invest in one of these. I'd like to see what's going on under the water inside the limber hole.
hillenme is offline
post #34 of 88 Old 05-15-2013
asdf38's Avatar
This is a good one:
Milwaukee M12 12-Volt Lithium-Ion Cordless M-Spector 360 Digital Inspection Camera (Tool Only)-2313-20 at The Home Depot
Although it's another $100 if you don't already have the battery and charger (Though the M12 line is great if you happen to be in need of any new cordless tools. I couldn't live without my cordless rotary, multi-tool and right angle drill).
I have a milwaukee one but not this one with the rotating screen. It's been handy for electrical work and boat work. The rotating screen deals with the issue of camera orientation. Without the rotation I find it surprisingly tricky to keep track of up and down properly so I consider that a pretty big plus.
asdf38 is offline
post #35 of 88 Old 05-15-2013
Hmm! Tightening the keel boats only works if the boat is resting on its keel. Doing it in the water??? Not to be an alarmist but you are getting quite a bit of water with the boat not under any load. Put on the backstay, load up the rig and pound through a few of those nasty LM waves and you might have a much bigger leak than you thought. Best bet is to do it right. Have it hauled and checked. Tighten bolts and really have a good look inside that stringer. Was water trapped in there during the winter and then frozen. The freeze/thaw cycle with entrapped water can can cause fissures in the glass. If the PO had it on a mooring in saltwater it probably never was a problem.
Good luck. My current C&C with the same construction has a bone dry bilge. My previous one had fissures caused by a grounding and a freeze thaw cycle. It leaked constantly and more so when loaded up under sail.
Sanduskysailor is offline
post #36 of 88 Old 05-15-2013 Thread Starter
hillenme's Avatar
The delivery was an almost 3 hour beat in gusts over 30 knots. Waves were 3 - 6. It took a pounding. Perhaps that trip was enough to turn a small leak into the large one I'm seeing now. Unfortunately, getting it hauled requires taking it the same distance back to the yard.
hillenme is offline
post #37 of 88 Old 05-17-2013 Thread Starter
hillenme's Avatar
Going to install an automatic bilge pump this weekend. I was thinking of installing a bilge counter as well to help me identify if it is getting worse. Someone from the yard came by the boat with me last night. He was just as stumped as to the source of the water and agreed it was not an obvious location like thru hull, water tank, keel boat, etc, but clearly under that stringer.
His only advice was get a bilge pump and keep an eye on it and they couldn't probably haul it until Memorial Day anyway - and he couldn't tell me how long it could take to get to a repair after that.
We had a great sail for about 2 hours - 15 knots of breeze, not too cold. The boat is surprisingly easy for just the girl freind and I to double-hand. When we returned I did not see evidence that the volume of water ingress increases when under sail.
hillenme is offline
post #38 of 88 Old 05-17-2013
rugosa's Avatar
CONDENSATION? Cold lake, warmer boat especially when closed up. Just thinking. Any results from methodically eliminating each and every thru-hull including instruments?
rugosa is offline
post #39 of 88 Old 05-18-2013
davidpm's Avatar
It would be really educational if you dry the bilge and take it for a sail in a stiff breeze for a couple hours.
Then compare the leakage rate with the rate at rest.
If it has anything to do with the keel you would think their would be a difference.
davidpm is offline
post #40 of 88 Old 05-20-2013
Asleep at the wheel
jimgo's Avatar
How did the weekend go? Did you get the bilge pump installed?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Leak on a 28-2 angus99 Cal 9 04-15-2014 10:47 PM
Stuffing box leak H and E Gear & Maintenance 7 05-07-2012 12:58 PM
*&%&$#ing Leak! sailordave General Discussion (sailing related) 20 03-30-2010 10:18 PM
A4 Carburator gas leak CalebD Atomic 4 5 12-05-2008 12:17 AM
Major Oil leak SaltyGirl Gear & Maintenance 14 04-02-2007 09:21 PM
