Antifreeze in water line - SailNet Community
 2Likes
post #1 of 37 Old 05-14-2013 Thread Starter
I just bought a used boat and i was going to flush out the holding tank and lines. I started to empty the tank by using the foot pump in the galley and antifreeze started coming out of the faucet.
Is it common to fill the water lines with antifreeze over the winter? I talked to the PO and he said this what he did every year. It just doesnt seam like a good idea health wise to me.
huntermj is offline
post #2 of 37 Old 05-14-2013
Asleep at the wheel
jimgo's Avatar
Re: Antifreeze in water line
Yes, as long as it is the red antifreeze, and not the yellow stuff. Yellow (automobile) is toxic; the red stuff is specifically designed to not be toxic.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 37 Old 05-14-2013
If it was an appropriate product, there is no health concern. However, getting the taste out may be impossible. I prefer blowing all the water out of the system instead.
chef2sail likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 37 Old 05-14-2013 Thread Starter
Yes it is red, I did not know there was such a thing. Thank you. I am going to empty it and flush the tank out.
I have so much to learn about this.
Well im off to the diesel engine section
huntermj is offline
post #5 of 37 Old 05-14-2013
MikeOReilly's Avatar
Completely common where it freezes. As long as it is plumbers anti-freeze (red stuff), then no problem. Flush the tank three or four times. Should get rid of the taste. You can use a basic carbon filter (brita-type) to remove any lingering taste.
Why go fast, when you can go slow.
MikeOReilly is offline
post #6 of 37 Old 05-14-2013 Thread Starter
Do you mean an inline filter? Thats a good idea.
This project list is never going to be done
jimgo likes this.
huntermj is offline
post #7 of 37 Old 05-14-2013
Asleep at the wheel
jimgo's Avatar
First boat?
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 37 Old 05-14-2013
We have an inline filter, but if you don't want to install one then a basic tap-mounted, or even filter-in-jug (Brita-style) will work. We winterize all plumbing with the stuff each year, so have to clean it out the following season. I find after two flushes I can't taste it, but my wife requires at least four. The carbon filter takes out most residual tastes.
post #9 of 37 Old 05-14-2013
overbored's Avatar
Done? there is no such thing in boating. there is only another project.
Propylene glycol is edible found in may foods. ever eaten a pop cycle, it what keeps them from breaking your teeth. ethylene Gylcol is not good to eat and can kill you. both taste almost the same
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 37 Old 05-14-2013 Thread Starter
Originally Posted by jimgo View Post
First boat?
First sailboat and first boat with a sink, freezer, head, hot water heater, diesel engine, solar panels, wind generator, radar, chart plotter and so on.
Im a little over whelmed with so many new systems to learn at once.
And everything seams to be tied into everything else. And nothing is designed like their counter parts on land
huntermj is offline
Water (system) line question chrisncate General Discussion (sailing related) 8 01-04-2011 01:14 PM
Automotive antifreeze vs. RV antifreeze for engine. dman535 Gear & Maintenance 18 09-30-2009 04:53 PM
PEX vs PVC reinforced water line PeteSS Gear & Maintenance 1 06-15-2009 11:44 PM
32-26 water line rockybucci Island Packet 4 07-09-2007 09:05 PM
Is winterizing/antifreeze needed for in-water boat on Vancouver Island? FrankLanger Gear & Maintenance 5 09-20-2006 07:19 PM
