Backing plate FG hull - Another Bonding approach - SailNet Community
post #1 of 2 Old 05-16-2013 Thread Starter
DrB
So I have replaced all of my Thru-Hulls and doing the last three this w/e.
None of them were through bolted before the fix.
I did Maine Sails approach of a threaded rod into a backing plate that was then epoxied to the inside of the hull. This approached worked well for the engine intake, but when I did it for the cockpit drains, (1-1/2" Thu-Hulls) I had a hell of a time releasing the thru-hulls after the dry-fit/epoxy cure of the back plates to the hull. Even though I waxed the hell out the all thru-hull and and backing nut, ultimately they didn't release and I needed to cut the backing nut, wack the thru-hull, and then just got it to break using a huge cheater bar.
A guy in the yard, who worked built ships for the Navy and now has a business fixing commercial and pleasure boats, suggested not using filled epoxy, but a high strength bedding compound for the backing plate. He first suggested through bolting to the hull, but I don't want to do that. After I told him about the backing plate idea, which he had heard of, he suggested a high quality and strength adhesive, like 4200 or 5200 for the back plate to the hull.
So the $64,000 question: why the need for epoxy and can I use high-strength adhesive instead?
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #2 of 2 Old 05-16-2013
tommays's Avatar
Re: Backing plate FG hull - Another Bonding approach
I had no problems doing it using a good coating of grease
While 5200 is strong it is not remotely close to epoxy in strength
I guess the question is how strong is 5200 when holding a disk with 9 square inches of surface are ,and would the metal be just as likely to stick if the realse coating did not work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Would A Hardwood Be An Acceptable Backing Plate Baysailor34 General Discussion (sailing related) 22 05-22-2011 12:58 AM
Backing plate weephee General Discussion (sailing related) 4 05-17-2010 10:17 AM
Backing plate options WesterlyPageant Gear & Maintenance 6 09-16-2009 04:22 PM
Backing Plate Size? WhatTheFoley Gear & Maintenance 34 07-22-2009 12:01 PM
To backing-plate or not, that is the question brak Gear & Maintenance 5 07-09-2007 08:13 PM
