Boom assembly - SailNet Community
 1Likes
  • 1 Post By Hudsonian
post #1 of 8 Old 05-16-2013 Thread Starter
JoeLena's Avatar
Boom assembly
So I have a new boom, sliding gooseneck and end cap, but not sure how the gooseneck and cap stay attached to the boom. There doesn't seem to be any way to secure either. They just fit snugly in the boom. There are 6 pop rivets that came with the parts, but I have no idea how they might be used to attach the gooseneck.
Here is what it looks like:
Anyone point me in the right direction?
JoeLena is offline
post #2 of 8 Old 05-16-2013
Re: Boom assembly
Assemble the boom and end fitting, drill through one wall of the boom and and fitting, and pop rivet in place. Since they gave you three rivets for each fitting, I'd guess that you'd place the pop rivets at 10:00, 2:00, and 6:00.
Alternatively, assemble the boom and fitting, drill through one wall of the boom and fitting, tap threads, and and install SS machine screws
rugosa likes this.
Hudsonian is online now
post #3 of 8 Old 05-16-2013
Re: Boom assembly
Slide the parts together tightly, drill through the boom and the inner 'shoulders' of the fittings the right size for the rivets, then get hold of a pop rivet tool and put them together.
What boat is this on?
Faster is offline
post #4 of 8 Old 05-16-2013 Thread Starter
JoeLena's Avatar
Re: Boom assembly
Thanks for those fast replies. I guess that makes sense. It seems like those pieces are solid, I was not sure I could drill just part way and pop a rivet into them.
It is for an O'day Rhodes 19.
JoeLena is offline
post #5 of 8 Old 05-16-2013
Re: Boom assembly
Solid?? really?? I'd expect a 3/16 or so thickness on the parts that go into the boom section. If they are solid then you'll be better off drilling and tapping and using machine screws, or, as our Selden rig has, drilling and using self tapping screws to hold the end caps.
A rivet is really meant to have the room to expand beyond the bore, so simply drilling a dead ended hole may not work too well.
Faster is offline
post #6 of 8 Old 05-16-2013
minnow1193's Avatar
I have almost identical fittings on the ends of my boom. They are screwed in with self tapping screws.
minnow1193 is offline
post #7 of 8 Old 05-16-2013 Thread Starter
JoeLena's Avatar
Re: Boom assembly
Okay, I will check on the thickness, maybe they just appear solid, they are hefty. But I bought it all together from Dwyer, I'm sure they would not send rivets if something else were needed.
If the rivets will not do I will try the self tapping screws. I appreciate all of the responses.
JoeLena is offline
post #8 of 8 Old 05-17-2013 Thread Starter
JoeLena's Avatar
Re: Boom assembly
There was a 'shoulder' to drill thru and pop rivets into, so I am all set now. Thanks for all of the assistance! Now just need some help stepping the mast and I'm on my way.
JoeLena is offline
Air Cleaner Assembly Afrakes Diesel 2 02-15-2012 05:36 AM
rudder assembly 77 44ft pmccharles Irwin 1 09-07-2008 03:54 PM
Help need a spool assembly for CDI Furler wendellf Gear & Maintenance 0 06-09-2006 09:04 AM
need help with a coumbia 22 rudder assembly harleyguy Gear & Maintenance 0 04-04-2002 11:14 AM
Tayana 37 Rudder Assembly srubin General Discussion (sailing related) 0 12-03-2001 07:11 AM
