Autohelm 4000 - SailNet Community
post #1 of 14 Old 05-16-2013 Thread Starter
Autohelm 4000
Hi. I have an autohelm 4000 and the controller unit has stopped working - no power. I've reviewed the guidance here and have checked the power cable coming out of the unit. After adjusting the cable, the power was restored to the unit. The turn to "+" buttons work (both of them) but the "-" buttons do not work. Any thoughts? Any suggestions on who might be able to repair the unit or anyone out there have one they are looking to sell? I've checked ebay, but have found nothing.
Many thanks, in advance, for whatever guidance you might be able to provide.
Doug
hdfleishman is offline
post #2 of 14 Old 05-16-2013
rugosa's Avatar
Re: Autohelm 4000
Autohelm was rolled into Raymarine. They have an excellent service department - Raymarine Marine Electronics for Boats and Maritime Applications
rugosa is offline
post #3 of 14 Old 05-16-2013 Thread Starter
Re: Autohelm 4000
Thanks for that. All indications that I've seen are that they have stopped supporting the 4000.
post #4 of 14 Old 05-17-2013
Re: Autohelm 4000
I had a similar problem with my Autohelm 3000 last year. I contacted Capt Dan In Durango. Turned out my unit needed a new internal compass and a few other minor repairs. He was very reasonable and did quick service for me.
I highly recommend him. You can contact me for his email address as I am unable to list it here according to Sailnet rules.
Mike
heelangle is offline
post #5 of 14 Old 05-17-2013 Thread Starter
Re: Autohelm 4000
Mike - that sounds great. Thank you. Unfortunately, I cannot send you a private message because I do not have sufficient posts on this board. Are you in a position where you can send me a message?
Doug
post #6 of 14 Old 05-17-2013
jimrafford's Avatar
Re: Autohelm 4000
contact him via email c250@mydurango.net. He fixed my autohelm last fall.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #7 of 14 Old 05-17-2013 Thread Starter
Re: Autohelm 4000
Thanks!
post #8 of 14 Old 05-19-2013
bblument's Avatar
Re: Autohelm 4000
Thanks for the info. I have an Autohelm 1000 that I've been tinkering with. At first it didn't work at all, but I discovered some bad brushes and a lot of corrosion on the brush springs of the motor. After cleaning them up, it sort of works... just sporadically. I sometimes have to give the extension arm a little nudge to get the motor going, but all the other functions work correctly. Any ideas on what to check next? A source for a new replacement motor?
Thanks...
Barry
bblument is offline
post #9 of 14 Old 05-19-2013
s/v Tiger Lily
dvuyxx's Avatar
Re: Autohelm 4000
I also have a dead 4000 control head. They are indeed no longer supported or serviced and the newer controls are not backwards compatible with the 4000 wheel unit. My control head is damaged because of moisture breach. You can see standing water in the LCD display!
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #10 of 14 Old 05-19-2013 Thread Starter
Re: Autohelm 4000
Barry - my malfunction is with the control unit, not the motor. I am going with Mike / Jim's advice and have already reached out to Captain Dan. I am hopeful.
David - with respect to your question, I have the older unit that does not have an LCD. Sorry I cannot be more helpful.
Tags
autohelm 4000
Autohelm 4000 sabre39RG SailNet FAQ 2 08-12-2011 11:56 PM
Autohelm 4000 Sailartist Electrical Systems 12 08-16-2010 10:03 PM
Autohelm 4000 sailnaway Gear & Maintenance 4 09-09-2009 11:36 PM
Autohelm 4000 k7pqs Gear & Maintenance 8 12-06-2008 10:31 AM
Autohelm 4000 Booher Gear & Maintenance 4 10-15-2003 05:09 PM
