Lewmar Commander Hydraulic problems - SailNet Community
post #1 of 1 Old 05-17-2013 Thread Starter
I have hydraulic winches and windlass connected to a single Lewmar Commander hydraulic pump...installed in the early 1990s I suspect. Never given me any trouble until recently the winches would randomly not seem to work. Cleaned electrical connections, topped off the hydraulic fluid, but I notice that the pump makes a lot of noise even when not under a load. The heavy wire running to the pump gets very hot, and after running a while, the pump cuts out completely. I suspect a thermal cut-out switch is tripped because the electric motor gets very hot.
Anyone have experience with these units? A plugged hydraulic line/filter? Worn brushes on the motor? Not sure what I should check next as pulling the whole thing out of the stern will be a big job.
Thanks for any suggestions!
Uliad54 is offline
Hynautics Hydraulic pump problems mcmichaelmcmahon Gear & Maintenance 1 03-29-2013 11:11 PM
Restoring a Commander sealface Pearson 8 11-11-2011 05:28 PM
Bianca Commander 31 Hmm Sailboat Design and Construction 1 10-31-2010 09:11 PM
Commander 31 bayme Boat Review and Purchase Forum 0 02-09-2003 01:29 PM
Lewmar Commander 4 Solenoid Replacement sci_fi Gear & Maintenance 1 01-23-2001 03:53 AM
