What is This Piece of Metal on my Boom - Page 2 - SailNet Community
post #11 of 18 Old 05-17-2013
Re: What is This Piece of Metal on my Boom
I have seen something like this for attaching the boom to a hook on the backstay, in place of a true topping lift. But as you have a topping lift, I am with the rest of the gang.
paul323 is offline
post #12 of 18 Old 05-17-2013
Stray bit of metal in a place where skulls might be found?
Yeah, the technical word for that is "an accident waiting to happen".
But I'd agree, the topping lift could go there. ALthough it looks like a topping lift would be perfectly happen on that eye on top of the boom, and less likely to gash anyone or foul anything.
hellosailor is offline
post #13 of 18 Old 05-18-2013
rhr1956's Avatar
That boom looks just like the one on my Pearson 26. The metal strap is what the mainsheet traveler's upper block connects to.
rhr1956 is offline
post #14 of 18 Old 05-18-2013
The metal piece looks like it could be part of a boom roller reefing system. The topping lift would be attached and the boom allowed to rotate whith the lift attached. Check to see if there is a place to insert a crank at the boom end near the mast.
Charlie
mathcr is offline
post #15 of 18 Old 05-20-2013 Thread Starter
Sundance 23
carl762's Avatar
There is a little crank up at the mast that's mystified me since buying the boat. It's very small.
Must take more pictures, but I just can't seem to get myself down there, as I'm currently hating the boat, for more than one reason.
I'll get over it.
Water is Life
carl762 is offline
post #16 of 18 Old 05-20-2013
The small crank should have a place, near the mast end, for it to insert and crank in order to roate the boom for reefing. The topping lift must be attached to that 'metal piece' at the end of the boom.
I had boom roller furling on my 1965 Hood design 24 ft boat. It was not a great system, had to have someone pull on the end of the sail as it got cranked in oder to have a good sail shape. I changed over to jiffy reefing and never regretted it.
Charlie
mathcr is offline
post #17 of 18 Old 05-20-2013
flo617's Avatar
On my boom I have two of these pieces. One attaches to the mainsheet blocks. The other is just hanging around. I sort of figured out it connects to the hook that is crimped to the backstay in order to stabilize the boom without using the mainsheet when the boat is at dock. Of course, that might not be the real reason for it...
Florent
flo617 is offline
post #18 of 18 Old 05-20-2013
s/v Tiger Lily
dvuyxx's Avatar
Yeah, that is the piece that gives you a lacerated scalp or at minimum rips your clothing when your tying your sails. Whatever it is, I would guess it is upside down and used to stick above the boom. Is it tight or loose?
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
Your ONE piece of wisdom... MedSailor General Discussion (sailing related) 150 06-05-2012 04:32 AM
Hunter 28 really a piece of ****? TheSeaPenguin Boat Review and Purchase Forum 16 10-03-2009 01:03 AM
Restoring shine to metal parts (cleats, port hole metal) saurav16 Gear & Maintenance 23 11-19-2008 06:42 PM
Two piece mast? L124C Sailboat Design and Construction 3 10-20-2007 11:05 PM
