Smoke in W60 engine compartment - SailNet Community
post #1 of 3 Old 06-23-2004 Thread Starter
I''m experiencing a tiny bit of wispy smoke coming from one side of my Westerbeke 60 engine (near raw water pump, thumb pump for bleeding, exhaust elbow, fresh water coolant reservoir, etc.).
My question is this: If the raw water pump impellor were melting or shredding, would that produce visible smoke in the engine compartment??
What else might be causing this. It is a tiny amount of barely detectable smoke (need flashlight to see it) that sometimes sets off my smoke detector; sometimes doesn''t.
Thanks for your input.
pma_foyl is offline
post #2 of 3 Old 07-01-2004
Hi Paul, hope the ''wispy Westerbeke'' issue has been sorted. Good luck on the uphill climb with a ''new'' used boat!
Jack
WHOOSH, lying Helsingborg, Sweden where the bad weather just doesn''t want to give up!
WHOOSH is offline
post #3 of 3 Old 07-01-2004
I have noticed a burnt rubber smell after motoring from an impellor starting to disintegrate but no smoke. I would suggest checking your exhaust system for minor leaks. A little oil in the wrong place (hot) can also produce a lot of smoke if you have any leaks or spillage on engine. Just a couple drops could be pretty strong in the cabin.
capttb is offline
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
Smokin'' Perkins cgha33 Gear & Maintenance 5 11-13-2003 09:19 AM
Engine Exhaust/Yanmar Problem plong Gear & Maintenance 5 08-30-2001 10:46 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
