Battery Charger Recommendations - SailNet Community
post #1 of 13 Old 05-18-2013 Thread Starter
BGS
Anyone recommend a decent charger for regular deep cycle batteries? I will be leaving the boat for a week or two at a time so I need something to maintain a charge but not overcharge. Thanks for the help.
BGS is offline
post #2 of 13 Old 05-18-2013
Maine Sail's Avatar
Re: Battery Charger Recommendations
At a dock, in the driveway? Via shore power 50A, 30A service etc.? What size bank? What type batteries?
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
BGS (05-21-2013)
post #3 of 13 Old 05-18-2013
night0wl's Avatar
If I ever replace my truecharge (oem), it will be an iota branded charger. They're not marine, but full featured and well regarded by the community.
S/V Jendai
Beneteau 343
night0wl is online now
The Following User Says Thank You to night0wl For This Useful Post:
BGS (05-21-2013)
post #4 of 13 Old 05-19-2013
Get a Battery Desulfator.
Flybyknight is offline
The Following User Says Thank You to Flybyknight For This Useful Post:
BGS (05-21-2013)
post #5 of 13 Old 05-19-2013
Just don't overcharge. 13.5 volts for 4 years on a battery and there will be nothing left of the positive plates. That's what happened to my flooded lead acid marine deep cycle battery that was being used for backup power. 13.2v is the limit for continuous floating at room temperature.
steel is offline
post #6 of 13 Old 05-20-2013
Chartreuse's Avatar
Check out harbor freight, I think they have a 1.5 or 2 watt solar trickle charger. That should keep it up, anything bigger and youll want a protecter to keep from overcharging. Just keep the bird poop off of it.
a website:
http://www.advrider.com/forums/showthread.php?t=756641
Chartreuse is offline
The Following User Says Thank You to Chartreuse For This Useful Post:
BGS (05-21-2013)
post #7 of 13 Old 05-20-2013 Thread Starter
BGS
Thanks for the replies. It will be at the dock on a single 30A. Bank is two 12v deep cycle/ cranking.
BGS is offline
post #8 of 13 Old 05-20-2013
chef2sail's Avatar
Get a three stage charger. You didn't mention battery type so make sure it has different settings ( wet, AGM, gel).
Do some research about electrical systems as after the sils, engine, it s the next critical and expensive system on the boat. You will also eventually want a battery Monitor like a Victron.
I suggest you buy a charger which would handle you upgrading the batteries in the future so at least 20 amp.
Learn what desulfating you batteries means or prolonging their life.
Battery chargers come in all different prices and features. We have a Mastervolt 40 amp and re very happy with it.
http://www.marinewarehouse.net/mastervolt.html
http://www.jamestowndistributors.com...51843&type=pla
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
The Following User Says Thank You to chef2sail For This Useful Post:
BGS (05-21-2013)
post #9 of 13 Old 05-20-2013
chucklesR's Avatar
Amazing, absolutely amazing that folks come back with specific answers with no knowledge of what the charger is for.
Get a bicycle, hook it to a alternator. If that doesn't work call me on the coconut radio.
chucklesR is offline
post #10 of 13 Old 05-20-2013
Señor Member
PorFin's Avatar
BGS,
Here's the thing -- in order to get the best solution, you need to take a lot of variables into account (hence MaineSail's questions.)
What we know:
1. You want a new charger.
2. It will be fed using a 30A shore service.
3. You have two 12V deep cycle/cranking batteries as your house bank.
What we don't know:
1. What is the battery chemistry? (flooded, gel, AGM?)
2. What is the bank capacity in amp hours at the 20 hour rate?
3. Are there any loads on the batteries while you are away from the boat? (i.e., are you leaving a fridge running or something else that will draw juice out of your batteries?)
4. How much money are you looking to spend?
________
'85 BYB Vagabond 39
PorFin is offline
The Following User Says Thank You to PorFin For This Useful Post:
BGS (05-21-2013)
Battery Charger and Battery Switch lobosolo98 Electrical Systems 11 10-10-2012 11:34 AM
Need a charger - recommendations? calden Electrical Systems 15 08-11-2010 11:02 PM
Iota charger recommendations cutterorient Gear & Maintenance 8 12-09-2009 03:42 PM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 09:30 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 01:43 AM
