Transom extension--pulling molds from the side of the hull - SailNet Community
post #1 of 2 Old 05-18-2013 Thread Starter
pdqaltair's Avatar
I'm think of adding some short extensions to my hulls to help some disabled access and boarding issues. Just enough to give a small platform, about 18 inches:
http://sail-delmarva.blogspot.com/20...-transoms.html
Though I've read numerous stories of folks building extensions, I've never read of anyone using the hull itself to generate a form with matching compound curves. More often they use some flexible material and battens and settle for a straight run, which is fine I suppose; I may go that way. I've know folks to pull molds from the hull to repair damage (pull a mold from the other side of a cat); they just waxed it well and laid up a few layers of glass.
Any practical advise? I'm only talking about 2 x 4 ft^2 areas. I suppose I could use a release film, but I wonder if the surface would be as good.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #2 of 2 Old 05-20-2013
Re: Transom extension--pulling molds from the side of the hull
CharlieCobra once posted fotos of a sugarscoop he added to a boat. Muck about in his threads and see if you can find those fotos. He did a really nice job, as you might suspect.
John
ccriders is offline
Tiller extension adapter for old & new extension CalAlida General Discussion (sailing related) 2 07-02-2010 09:48 AM
Hull extension on cat? dwightgry Sailboat Design and Construction 3 12-22-2008 01:07 PM
BIG Stuctural Problem? (Hull Stringers pulling away) RichP Gear & Maintenance 24 07-22-2008 12:36 PM
Bayfield 36 molds on ebay alajuelacutter General Discussion (sailing related) 0 05-22-2004 04:44 AM
Chainplate pulling away from hull JoeTrecker Gear & Maintenance 1 03-06-2004 03:11 AM
