Old 5 Days Ago
jameswilson29's Avatar
Senior Smart Aleck
jameswilson29 is on a distinguished road
Installed and tested second automatic bilge pump
Yesterday, I finished the installation and testing of a second automatic bilge pump.
The expertise of members of Sailnet (like Mainesail) has been a good influence on me: I used a heat gun to seal the butt connectors, instead of a lighter, my crimping techniques are much improved from some practice, my use of a direct connection to the battery bank with an waterproof inline fuse, bypassing the main switch and the circuit panel, my use of a vented loop instead of a check valve, etc., etc. Now, I did use corrugated line instead of the recommended smooth bore line because, in this case, the line diameter is not a limiting factor in the pump's capacity.
The video and photos:
Photos: https://plus.google.com/photos/10193...489?banner=pwa
  #2
Old 5 Days Ago
MastUndSchotbruch is on a distinguished road
Re: Installed and tested second automatic bilge pump
http://www.youtube.com/watch?v=ZuKIcxHOqO0
why is your new pump shaking so much when it is running? Didn't you screw it down or otherwise secure?
  #3
Old 5 Days Ago
Senior Smart Aleck
It is not secured. Should it be? It seems to work fine as is.
  #4
Old 5 Days Ago
how well will it pump if it tips over, e.g. in heavy seas?
  #5
Old 5 Days Ago
ccriders is on a distinguished road
I'm in the process of installing a new electric bilge pump with float switch and have a couple of questions:
Why did you decide to use the 3-way switch? I purchased the same switch but am now questioning its need. I'm thinking the pump should be wired to the main switch panel and that when I leave the boat I would leave that switch on and the main battery selector in the "both" position.
How did you run the hose and where does it exit the boat?
Did you try to run the wires along the bundle that Pearson installed in the port settee locker?
Thanks
John
Ps. I glued a small disc of starboard to the bottom of the bilge and then screwed the pump to the starboard being careful that the screws did not penetrate the floor of the bilge.
  #6
Old 5 Days Ago
bblument is on a distinguished road
Thanks for posting that. Very helpful.
Barry
  #7
Old 5 Days Ago
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Yes. It should be secured. Think about what happens when the boat heels, and/or you are going upwind into a steep chop.
Ideally, everything in the boat should stay in place if a knockdown/capsize. Few boats are that well prepared, but at the very minimum one should have some confidence that safety gear (such as a bilge pump) will keep operating after a serious event.
LET'S GET SERIOUS ABOUT GUN CONTROL, NOW!
Last edited by SlowButSteady; 5 Days Ago at 11:46 AM. Reason: Can't have chrisncat pitch a hissy fit because of a typo
  #8
Old 5 Days Ago
Senior Smart Aleck
I wanted to be able to test the pump without putting water in the bilge. With the manual switch, I can test it.
My other automatic bilge pump was wired through the main switch panel. I wired this one directly to the battery to make it even more fail safe. I will not forget to leave the battery switch on, I will not forget to leave the right circuit switch on, the pump will work even if the circuit or the switch fail.
I ran the hoses and the wire under the sole to the port side of the forward end of the engine compartment then up a gradual incline about 3 feet into the port cockpit locker to a vented loop just under the cockpit locker lid then down along the side of the cockpit to the transom at approximately the same height as the engine exhaust, above 2 feet about the waterline. The hose was secured with ties wherever I could find a good point to secure it.
I will probably use the same method as the PO for the other automatic bilge pump and bend a piece of lightweight metal screwed into the rib/stringer just on top of it to hold it in place.
  #9
Old 5 Days Ago
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
A 3-way switch is especially useful when (not if) the float switch fails.
  #10
Old 5 Days Ago
Thanks,
I still cannot decide about the 3-way switch.
Be sure you don't puncture any of the fiberglass encasing the wood stringers and floors as surely rot would ensue.
John
You may post attachments
You may edit your posts
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
Best Automatic Bilge Pump for a 1987 CS30? HBBurlington Gear & Maintenance 1 06-23-2011 11:09 PM
Whale 650 automatic bilge pump electrical issues? brianontheroad Gear & Maintenance 5 10-17-2010 06:09 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Automatic Bilge Pump Won't Shut Off zoom555 Gear & Maintenance 5 07-06-2009 04:22 AM
SEO by vBSEO 3.6.1
