Pearson 26 mast support - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 05-20-2013 Thread Starter
bblument's Avatar
Re: Pearson 26 mast support
RHR...
Perfect! That concise, clear list lets me know exactly what I have to do; exactly what I was hoping to find. I can't thank you enough.
Barry
bblument is offline
post #12 of 17 Old 05-30-2013
Hi got some pictures but don't seem to be able to send through sailnet.If you have a email I could send them to I could do that.I don't know how much good they will do you. Karl
karlos is offline
post #13 of 17 Old 05-30-2013
Ticon 30
dbruce85's Avatar
I believe it is a common problem on the P26 ( still miss mine, she was an incredable sailing boat).
Mine was replaced before I had bought her, I believe it was replaced with solid maple.
Enjoy your boat!
dbruce85 is offline
post #14 of 17 Old 05-31-2013
TQA
Bombay Explorer 44
TQA's Avatar
If you have not already found it there is a Plastic Classic Forum here Plastic Classic Forum ? Index page
A wealth of useful info including much on the early Pearsons.
TQA is offline
post #15 of 17 Old 08-01-2013
Hi I am a new pearson 26 owner and in march I replaced my mast support beam. I too had the door replaced with a curtain but I did get the old solid door . I used solid white oak for the new support. The local marina when they rewired the mast drilled in to the side of the support and put a s/steel pipe in the support and the previous owner had injected large amounts of epoxy into the support to fix the rot.
papalearn is offline
post #16 of 17 Old 08-04-2013 Thread Starter
bblument's Avatar
Just following up. I've got the whole thing taken care of. New laminated white oak beam, new white oak compression strips, new russian birch plywood bulkheads (edges sealed w/ epoxy, faces with 7 coats of spar varnish), new mast wiring, holes through deck for wiring and mast step bolts lined w/ epoxy and chamfered, mast step plates sealed w/ 4200, mast completely rewired, gooseneck for the wires made from bicycle innertube attached to riser on mast step to prevent water from even reaching the wiring passageway in the step and deck... came out great! I have mast lights! A strong, solid support for the mast! An attractive cabin (well, at least this part!). Thanks to everyone for all of your great help. I've attached a pic. Still a few trim pieces I'd like to add to cover the small spaces between the bulkheads and compression posts, but not bad if I do say so myself.
Best to all..
Barry
Grcesq likes this.
bblument is offline
post #17 of 17 Old 08-05-2013
rhr1956's Avatar
Best to all..
Barry
Good job. Lot of work but looks well done.
rhr1956 is offline
Tags
compression post , rot
Mast Support During Trailering windyway North American Yachts 3 12-18-2012 10:32 PM
Cal 20 mast support question herocomplex Cal 2 06-11-2010 03:30 PM
replacing mast support Krow Gear & Maintenance 3 01-04-2010 03:06 PM
moving support for deck stepped mast ramminjammin Sailboat Design and Construction 11 12-03-2009 02:05 PM
Cal 34 deck/mast support Jrod63 General Discussion (sailing related) 4 09-22-2006 02:45 PM
