5200 Bond - SailNet Community
post #1 of 13 Old 05-19-2013 Thread Starter
5200 Bond
Has anyone had success in using WD40 or lighter fluid in getting 5200 to release it's bond on porthole windows? I know there is a product out there for this application but I'm just looking for a cheaper alternative.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #2 of 13 Old 05-19-2013
Senior Moment Member
SloopJonB's Avatar
Re: 5200 Bond
Sweat.
SloopJonB is offline
post #3 of 13 Old 05-19-2013 Thread Starter
Re: 5200 Bond
Originally Posted by sloopjonb View Post
sweat. :d
lol
misfits is offline
post #4 of 13 Old 05-19-2013
But if not...
Re: 5200 Bond
anti-bond, sharp knife, patience, bad words...
... and sweat.
paperbird is offline
post #5 of 13 Old 05-20-2013
Señor Member
PorFin's Avatar
Re: 5200 Bond
Misfits,
Bummer, dude... Now you know why 5200 is almost always the wrong choice for projects.
Anti-bond's probably the best alternative out there, but it's still gonna require a lot of work.
FWIW, for polysufide sealants I've had great success using PB Blaster as a bond breaker and to clean surfaces back to bare (but that probably won't help you for this one.)
________
'85 BYB Vagabond 39
PorFin is offline
post #6 of 13 Old 05-20-2013
JimMcGee's Avatar
Re: 5200 Bond
A buddy of mine claims to have had good luck with a new product called un-hesive. You can get it from Defender here.
I haven't had a chance to try it yet myself so YMMV.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #7 of 13 Old 05-20-2013
Stu Jackson's Avatar
Re: 5200 Bond
A hammer was too expensive for me to buy to bang in a nail, so I'm trying to find a cheaper screwdriver???
I just don't get it.
5200 is Satan's Glue, and unless it's all dried out and can come apart with sloooow pressure and wooden wedges, anti bond is about the ONLY thing I've ever heard of that works on that crap.
Beats breaking the ports.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #8 of 13 Old 05-20-2013
SloopJonB's Avatar
Re: 5200 Bond
I pulled a bronze port from a derelict wood boat yesterday. It was stuck in with what I assume was 5200 - if it wasn't it was the same rose by a different name. The port was very heavy & sturdy so I tried a variety of destruction methods - chisels, pry-bars etc.
Chewed up the wood pretty well but no movement of the port - at all.
Finally I tried a razor knife with the extendable segmented blades (Olfa). I slit it around the flange against the inside cabin side and then from the outside around the spigot. Had to repeat this a few times until I was sure I had bottomed out the knife from both directions.
After that it was a matter of prying on the flange and tapping on the spigot until it suddenly popped out onto the cabin sole.
If it was plastic you'd have to take it easier on the prying & tapping but it should work - if the plastic hasn't gone UV brittle.
The Following User Says Thank You to SloopJonB For This Useful Post:
oysterman23 (05-21-2013)
post #9 of 13 Old 05-20-2013 Thread Starter
Re: 5200 Bond
I knew I'd heard of an alternative & it was for polysufide sealants, thanks.
JimMcGee, thanks for the link. I'll order some in the am & post how it works.
Stu, getting cynical in your old age
SJB, yea it's going to be a slow painfull process. The salon ports are fixed & aluminum frames so I don't want to trash them. The smaller portlights are going to be replaced w/ opening ports but I'd still like to take them out in
a professional maner
Thanks,
Bob
misfits is offline
post #10 of 13 Old 05-20-2013
Re: 5200 Bond
When they remove an old car windshield, they use a wire. Thread it through, wrap it around a piece of wood on each side of the window, pull it around, cutting the sealant.
Just saying.
MarkSF is offline
The Following User Says Thank You to MarkSF For This Useful Post:
JimMcGee (05-20-2013)
3m 5200 NOLAsailing Gear & Maintenance 20 03-18-2009 08:48 AM
Flex-bond 5000 vs 3M 5200 xort Gear & Maintenance 2 02-11-2009 10:07 PM
New Use for 5200 Neicy Gear & Maintenance 5 05-01-2008 03:12 PM
3M 5200 JDAM Gear & Maintenance 10 08-08-2007 10:14 PM
To bond or not to bond, that is the question! wildcard Gear & Maintenance 2 12-04-2006 12:33 PM
