Can anyone identify these light fittings for me - SailNet Community
post #1 of 7 Old 05-20-2013 Thread Starter
TQA
Bombay Explorer 44
TQA's Avatar
I have several of these light fixtures on my 1978 New Bombay Trading Company Explorer 44. As you can see one of the light diffusers has broken. It looks like it was suffering from some kind of age related damage as it is crumbly along the edge.
Does anyone recognize the make of the light and more importantly know where I can get some new diffusers, the front piece that covers the tubes.
From Hoot Mon
From Hoot Mon
TQA is offline
post #2 of 7 Old 05-20-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Can anyone identify these light fittings for me
TQ .... my guess is that they will be long out of production. I've tried over the years to track down any number of older lights for boats but for whatever reason they seem to have a short production life. I'd try a couple of methacrylate/perspex suppliers. You may luck out and find an extrusion that matches the curve of your diffuser and could then get it cut to size.
cheers
Andrew B
Andrew B (Mal 39 Classic)
Life is a trick, and you get one chance to learn it.
― Terry Pratchett.
tdw is offline
post #3 of 7 Old 05-20-2013
Found what may be the current version on E-bay but no clues as to manufacturer to assist in locating parts. I've replaced a FL tube fixture in the head with a red/white LED strip that was $10 cheaper than what they are asking for this one.
http://www.ebay.com/itm/12-VOLT-BOAT...item4cf1eee543
capttb is online now
post #4 of 7 Old 05-21-2013
Omatako's Avatar
It's hard to tell from the pics but I believe these diffusers have open ends with the light fitting forming the end closures?
If they do they're real easy to make. Just a former of some sort, perhaps polystyrene pipe sleeving or whatever you can find that's a similar radius.
Get some perspex that's the same sort of thickness as the diffuser material, cut it more or less to size, stick it into a moderately hot oven for a few minutes to soften it up then fold it over the former and hold till cool. When cooled it will hold its shape.
Then trim to size. It works and it's easy - I've made many such parts over the years using this method
Arthur C. Clarke
Omatako is offline
post #5 of 7 Old 05-21-2013 Thread Starter
TQA
Bombay Explorer 44
TQA's Avatar
I guess I will have to go down the DIY route unless I want to replace the whole fitting.
The lights are good and have the option of red light for night sailing as well as white so replacements are quite expensive down here in the Windward Islands.
TQA is offline
post #6 of 7 Old 05-21-2013 Thread Starter
TQA
Bombay Explorer 44
TQA's Avatar
Found them.
They are called Guest Fluorescent Red/White Lights and are shown as current in the Budget Marine catalogue in Grenada.
Whoopee.
TQA is offline
post #7 of 7 Old 05-22-2013
rhr1956's Avatar
From Hoot Mon
From Hoot Mon
My friend Brock has a 50' motorsailer with about 10 fixtures that look exactly like yours. He converted all of them to LED and made new diffusers. I'm not sure what he used but he can tell you. Call him at West Marine in Garland, TX. He is very friendly and possesses a wealth of boat knowledge.
rhr1956 is offline
Hi Mod fittings casey1999 Gear & Maintenance 18 02-03-2014 01:28 PM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 05:48 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 01:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 10:44 AM
Thru Hull Fittings nauticalrich Gear & Maintenance 4 04-04-2002 02:33 PM
