Ratchet straps - Page 2 - SailNet Community
post #11 of 16 Old 05-21-2013 Thread Starter
Re: Ratchet straps
Originally Posted by Captainmeme View Post
What is wrong with just replacing the strap? And why do you have to leave it at the canvass shop? The canvass guy just needs to know the width and length of the strap and how long to make the loop
The strap is permanently sewn onto a hook at one end and the ratchet on the other.
Jeanneau 54DS
Minnewaska is offline
post #12 of 16 Old 05-22-2013
cvsheppard's Avatar
Re: Ratchet straps
Here is a site that might offer you a suitable rachet.
http://www.steritool.com/tools/tie_down.htm
Carl
s/v Credence II
PSC 34 #159
Portland, Or
cvsheppard is offline
The Following User Says Thank You to cvsheppard For This Useful Post:
T37Chef (05-22-2013)
post #13 of 16 Old 05-22-2013 Thread Starter
Re: Ratchet straps
Thanks for the link. I'm not sure if 304 stainless is good enough or not. The ratchets don't typically soak with salt water, but I'm sure 316 is better. I know what I have are SS, but no idea what grade.
The most interesting thing is that no one, including this vendor, seems to sell a ratchet with a loop on one end to tie off with a larks head. It seems so simple. I really don't want a clip on the stanchion and even wrapping the stanchion and then clipping it back on its own webbing would seem to allow for chafing.
I got through to the prior owner who claims to have only purchased from Kato, including the odd looking third tie down.
I can't believe I may dump a couple hundred dollars on tie downs. That's crazy.
Jeanneau 54DS
post #14 of 16 Old 05-22-2013
ebs001's Avatar
Re: Ratchet straps
Buy some cheap ones from Home Depot as a temporary measure. Then, have your old ones restitched at the canvass shop. If you want and the temporary straps look no worse for ware return them to HD for a refund - they weren't suitable for the intended job.
The straps at HD are around $14 to $18 for what you need. So even if you don't return them you'll only be out less than $20 and they are useful on land as well.
ebs001 is offline
post #15 of 16 Old 06-05-2013
Re: Ratchet straps
I second the recommendation above for StrapWorks
( strapworks.com )
They have many combination of ends and loops. Hardware and ratchets are available in stainless. Webbing is available in UV resistant materials in verious load ratings (widths & thicknesses). My experience was good. Good luck, Bob
bobsaxet is offline
post #16 of 16 Old 06-05-2013
chef2sail's Avatar
Re: Ratchet straps
If you can reserve 1 hour of the canvas mans time to take them to the shop and wait it shouldn't take more than that to set the straps into a loop and any other reinforcements you want around your original rachets..
I watched my wife replace ours and sew the replacement straps in less than 1/2 hour on her Sail rite machine.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Sail Straps? H and E Gear & Maintenance 4 02-14-2012 12:42 PM
Repairing the straps that hold rolled up eisenglass n0w0rries Gear & Maintenance 0 04-08-2011 04:37 PM
Going Aloft; Ratchet Block? WanderingStar Gear & Maintenance 6 10-30-2010 08:09 PM
Protect aluminium tiller straps??? donhaller Gear & Maintenance 6 05-01-2009 03:09 PM
Ratchet Block for Spinnaker Sheets TejasSailer Gear & Maintenance 4 07-12-2006 07:13 AM
