Outboard Motor Lift Bracket: 1 Me : 0 - SailNet Community
post #1 of 8 Old 05-21-2013 Thread Starter
Launched and motored my re-furbished Edel to her summer marina this past Saturday.
I still need to fix some deck hardware before sailing but one thing that I know is not easily working is the spring loaded bracket to lift the outboard.
When I docked I struggled to lift and push the release bar towards the back of the motor while at the same time trying to pull the motor up. I tried running a rope through the motors front lifting handle to the release bar but the bar still would not budge. Suddenly it popped and the motor came out of the water but I have no idea what the secret muscle flex was that caused this success.
The next day I could not get it to lower without using my 2 foot crowbar to pry up the release lever. When it drops though it does so with authority.
I cannot even imagine being able to successful raise the motor while sailing. I could tilt it up a bit but it would hit the transom after a few degrees of tilt.
Is there a secret that you folks can share? Is the bracket supposed to be lubed? Are the springs to be replaced every "x" years"?
I hate to spend the summer dragging my outboard. The 8 HP Honda weighs about 90#.
Thanks.
i_amcdn is offline
post #2 of 8 Old 05-21-2013
krisscross's Avatar
Re: Outboard Motor Lift Bracket: 1 Me : 0
I had an opposite problem - I had to fight to keep my motor in water. Ended up replacing the darned mount with a new one.
Plato
krisscross is online now
post #3 of 8 Old 05-21-2013 Thread Starter
I had something similar on my first docking. Tried to reverse but hit the throttle the wrong way, the motor went "WEEEEEEEEEEEE" and tilted itself out of the water. As I was heading for a collision I pulled the emergency lanyard and went forward to fend off the looming boat that I was approaching.
I should have mentioned that trying to reach back through the small "V" that the backstay adjuster forms only adds to the difficulty of hoisting the motor.
Could I attach a small block on the pigtail attached to the backstay? (That pigtail is the one used to support the boom instead of a topping lift.) or is the motor too heavy for the backstay.
Cheers and thanks.
i_amcdn is offline
post #4 of 8 Old 05-21-2013 Thread Starter
I am going to guess that the bracket I have is undersized for the 8HP Honda 4 stroke.
I will see if I can spot any bracket name.
Garelick Motor Mounts - Your Experiences
i_amcdn is offline
post #5 of 8 Old 05-21-2013
no longer reading SailNet
Alex W's Avatar
On the Garelick bracket on the Catalina 25 that I sail on you pull the handle towards the front of the motor, then lift, not the other way around.
It's non-intuitive and I have to show it to other crew on the boat multiple times before they get it.
Alex W is offline
post #6 of 8 Old 05-21-2013 Thread Starter
Non-intuitive maybe but it makes more sense your way. Seems safer too in that you are always pulling everything towards the boat.
i_amcdn is offline
post #7 of 8 Old 05-21-2013
c_witch's Avatar
Send a message via Yahoo to c_witch
Hi,
Our bracket was giving me problems last year in getting it up or down. Finally it seemed to get stuck in the up position. At that point the cavitation plate was only 3 inches under water but I could use it that way, but could only motor at 2 to 2 1/2 knots at most. This year I went out to have a good look at it before buying a new one. I finally decided to loosen the bolts holding the arms to the mounting bracket and lo and behold it now raises up and down very easily. I now feel stupid for not having thought of this last year. We have a Honda 7.5 which is quite heavy being a 4 stroker. This year I will add a few squirts of oil to the bolts during the season as well.
c_witch
c_witch is offline
The Following User Says Thank You to c_witch For This Useful Post:
i_amcdn (05-21-2013)
post #8 of 8 Old 05-21-2013 Thread Starter
Originally Posted by c_witch View Post
Hi,
c_witch
Thanks ...bolts will be checked and I will add some lubricant. It could be it is just rusted stiff after 3 years of non-use.
i_amcdn is offline
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 13 12-02-2014 11:55 AM
Outboard motor bracket HARDWORK Gear & Maintenance 10 04-09-2013 03:20 PM
outboard motor lift seapony2 Gear & Maintenance 2 10-02-2012 04:17 PM
Outboard lift davit for dinghy motor on 27' cal lans0012 Gear & Maintenance 8 08-19-2011 11:01 PM
OutBoard Motor Bracket for Peason 424 aphil138 General Discussion (sailing related) 1 06-08-2004 02:49 AM
