Manual water pump priming sucks so much .... - SailNet Community
post #1 of 8 Old 05-21-2013 Thread Starter
...that I have to lean over, turn my head upside down and suck on the pipe until I hear the gurgles getting closer. When I "feel" the gurgles I start pumping and water flows.
The boat has sat on the hard for over 3 years. Is it possible that some vital part has dried out? Is it worthwhile trying to diagnose and fix or should I simply replace it and go sailing? It is not a life or death matter but I do want it working eventually.
Thanks all.
i_amcdn is offline
post #2 of 8 Old 05-21-2013
Fresh water refugee
katsailor's Avatar
Re: Manual water pump priming sucks so much ....
This thread is worthless without pictures!!!
Actually I think something may be wrong. Go sailing instead
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #3 of 8 Old 05-21-2013
fryewe's Avatar
You have a leak. Fix it. You may have to replace hoses and fittings. If you have transparent hoses you should be able to see the water in the hose at the level it returns to when prime is lost. The leak is likely to be at that point.
fryewe is online now
The Following User Says Thank You to fryewe For This Useful Post:
i_amcdn (05-21-2013)
post #4 of 8 Old 05-21-2013
asdf38's Avatar
My experience based on 4 whale brand manual pumps (holding tank, sink, 2 bilge), is that you should not have to do this at all. My bilge pumps are 3-5' above the bottom of the bilge and have no problem priming at all.
So I'd first figure out what model/brand pump it is and search for a spares kit. If its Whale brand, which is common, you'll find it.
You can always replace the pump also but they are often expensive. I was forced to replace a whale gusher 10 and was surprised to find it was $260. I would have much rather serviced it for $50.
asdf38 is offline
post #5 of 8 Old 05-21-2013 Thread Starter
It looks like this Whale:
http://ca.binnacle.com/product_info....oducts_id=2216
I will check the hose (clear) and clamps and go from there.
Thanks
i_amcdn is offline
post #6 of 8 Old 05-21-2013
asdf38's Avatar
Thanks
That model is really common and the same one I have. Around here west marine sells replacements and usually stocks the service kits. Mine was busted on my boat, I never diagnosed the exact problem but after finding the parts kit on the boat and servicing it it worked fine.
It's great that products like this get manufactured so many years later. Mine was original (I believe), to my '79.
asdf38 is offline
post #7 of 8 Old 05-21-2013
Courtney the Dancer
jrd22's Avatar
Most diaphragm pumps are self priming to about 10'. I've used the Shurflo Washdown pumps for everything on the boat (fresh and salt), industrial equipment, construction equipment, etc and they are bulletproof (and relatively inexpensive). You can rebuild pumps but new and reliable works for me.
Edit: disregard, didn't realize you had a manual pump.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #8 of 8 Old 05-21-2013
Chastened
Ajax_MD's Avatar
You have a leak, but it's an air leak.
Air is leaking into the system, probably at the diaphram inside the pump. Hence, you lose prime, but no water leaks out of the system.
Here's what I did: Dismantle the pump and soak the diaphram in a light coating of veg oil. It's safe for humans, and often causes the rubber to swell and moisten, and retain its prime.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
Priming you water pressure pump CapnSantiago Gear & Maintenance 10 02-24-2013 09:08 PM
water bladder cleaning and manual pump repair xluke Gear & Maintenance 3 10-01-2011 04:42 PM
Priming Head Pump Out Hose L124C Gear & Maintenance 11 04-23-2010 12:21 PM
Water filter with manual pump faucet? IslanderGuy Gear & Maintenance 7 12-24-2009 08:06 AM
Manual priming lever stuck wchevron Atomic 4 0 04-24-2008 10:05 AM
