Magma Cabo BBQ meets Old World Mount - SailNet Community
post #1 of 3 Old 05-21-2013 Thread Starter
This brand new Magma Cabo was left by the PO. He had never gotten around to mounting it.
I have modified his fairly solid mounting bracket from his old BBQ by drilling 6 holes in it that are lined up with 6 of the holes that are in the really solid plate on the underside of the Cabo.
The normal Cabo mount only has 2 bolts and it only uses one clamp on the rail. The old mount has 2 clamps and with the extra 4 bolts into the BBQ I think it will be secure.
My question is :
Should I also drill a hole between the two clamps (hole would be where orange bobbin is shown in the attached) and then drill a hole through the rail and through bolt the mount. With that extra bolt there is no way that the mount would slip down.
It will be a small PITA to install and remove each year but with what I save on a new mount I can buy a few steaks.
Thanks
i_amcdn is offline
post #2 of 3 Old 05-21-2013
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Magma Cabo BBQ meets Old World Mount
I only have one mount on my Magma Catalina and it has seen close to a thousand miles and is fine. I sure didn't drill holes through the rail. You know they make special mounts for that... Or is that what you have?
Here is a pic...
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #3 of 3 Old 05-21-2013 Thread Starter
Yes I saw those mounts as well as the others that they have. I am just trying to save the money to buy a new clamp when I can re-use what was there before, albeit for a different BBQ. I will skip the through bolt as you suggest.
i_amcdn is offline
World Travels of a Cabo Rico aa3jy Cabo Rico 3 03-06-2013 11:06 AM
Magma Kettle 2 or Force 10? HBBurlington General Discussion (sailing related) 10 08-15-2011 02:34 PM
Magma Barbecue MLM2 Cruising & Liveaboard Forum 3 06-12-2009 08:54 PM
Golding Meets the Queen (Yachting and Boating World) NewsReader News Feeds 0 02-14-2007 04:15 PM
Magma Grill Question PhotoEd Gear & Maintenance 5 02-03-2006 10:16 AM
