Corroded electrical connectors - SailNet Community
 1Likes
  • 1 Post By desert rat
post #1 of 8 Old 05-22-2013 Thread Starter
rbyham's Avatar
I have two 4 pin connectors at foot of mast. Both work intermittently only after twisting. Is theresome way to clean kold terminals or should I just cut them off and wire direct with waterproofing?
rbyham is offline
post #2 of 8 Old 05-22-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Corroded electrical connectors
Not sure how to clean as I do not know what your terminals are made of. I would not wire direct though, you make need to remove the mast at some point. Just smother the connections in dielectric grease to keep the corrosion at bay
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #3 of 8 Old 05-22-2013
Large Member
GMFL's Avatar
I'd try to use some sandpaper around the pins to clean the corrosion off of them. Then see if you can find an awl or a needle and see if you can scrape some corrosion off the sockets. Use some wd40 to flush out the socket if needed. Check to see if that solves the problem then use the dielectric and wrap the connection with some rescue tape to try to keep moisture out.
Of course make sure the line is off prior to any of that.
GMFL is offline
post #4 of 8 Old 05-23-2013
Living the dream
ReefMagnet's Avatar
You could try soaking the connectors in vinegar for a short while and then cleaning with electrical contact cleaner. They're obviously exposed to the environment so use a slather of lanolin grease pushed into the connectors on reassembly. This will help keep corrosion at bay.
ReefMagnet is online now
post #5 of 8 Old 05-23-2013
electrical contact cleaqner 9contains a protective lube) and an old toothbrush,
GMFL likes this.
desert rat is offline
post #6 of 8 Old 05-23-2013
Have a look at this page for some ideas.
http://store.caig.com/s.nl/sc.2/category.188/.f
Transmitterdan
1995 Valiant 42
transmitterdan is online now
post #7 of 8 Old 05-23-2013
no longer reading SailNet
Alex W's Avatar
There is a tool available that is retractable fiberglass in a pen-shape. It works very well for cleaning stranded wire. I think generically they are just called a Fiberglass Pencil.
Starbrite makes one that is sold at marine stores:
Corrosion Buster Pen
Alex W is offline
post #8 of 8 Old 05-23-2013 Thread Starter
rbyham's Avatar
Thanks all... some good ideas here... I may try the pen if I can find it at WM tomorrow
rbyham is offline
sealing mast electrical connectors ctlow Electrical Systems 13 05-28-2011 06:35 AM
12V electrical connectors 88' PSC34 mondofromredondo Pacific Seacraft 2 11-28-2008 01:00 PM
wire and electrical connectors online witzgall Gear & Maintenance 10 01-05-2008 12:47 PM
'quick snap' marine electrical connectors?? tenuki Gear & Maintenance 9 06-04-2007 01:29 PM
electrical butt connectors GarrettK Gear & Maintenance 3 11-15-2004 12:57 PM
