!@#$ 5200!! - SailNet Community
 2Likes
post #1 of 20 Old 05-23-2013 Thread Starter
!@#$ 5200!!
I tried to finish what I thought would be an EASY project, but to no avail.
Deck-mounted starboard nav light was out, so I tried to remove the three screws that held the lense in place. Easy-peezy, right? Nope- the screws have apparently been bedded in with 5200, because they aren't budging.
One screwhead broke off, one will only work loose a little, and one won't budge at all. I tried Dremeling out a slot on the heads so that I could use a big flat head screwdriver, but that didn't work either.
So what to do now? Drill out the screws with a titanium bit?? That is the only thing I think might work.
FirstCandC is offline
post #2 of 20 Old 05-23-2013
Chastened
Ajax_MD's Avatar
Re: !@#$ 5200!!
Have any photos of these fixtures? Are you certain that they aren't thru-bolted with nuts on the back?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #3 of 20 Old 05-23-2013
Re: !@#$ 5200!!
Drill the screws out, refill the hole, and then drill and set it properly.
1982 Starwind 22 Mk II | Lake Lemon, Indiana |
(Previously posting as LemonHead)
CarpeAquam is offline
The Following User Says Thank You to CarpeAquam For This Useful Post:
FirstCandC (05-23-2013)
post #4 of 20 Old 05-23-2013 Thread Starter
Re: !@#$ 5200!!
Definitely not-through bolted. Going to drill 'em out.
post #5 of 20 Old 05-23-2013
Tartan 27' owner
CalebD's Avatar
Re: !@#$ 5200!!
TNT aka dyno-mite?
drill & fill.
Everybody has one:
CalebD is offline
post #6 of 20 Old 05-23-2013
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: !@#$ 5200!!
How does one keep the drill bit on the hard steel screw shaft when all the soft fiber-glass is so close?
It's not like you'd start with a smooth steel face that you can use a set punch on. The bit just wanders off the steel and into the FG. Maybe drill many holes with a smaller bit all the way around until the leftover screw piece falls out from sheer boredom? Then re-drill even bigger, fill and finally drill to size?
I got tired just typing that!
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #7 of 20 Old 05-23-2013
overbored's Avatar
Re: !@#$ 5200!!
drill around it and dig it out then re fill with epoxy and re drill for the screws. done it many times
"GOLD RUSH" PRINDLE 16
overbored is offline
post #8 of 20 Old 05-23-2013
rugosa's Avatar
Re: !@#$ 5200!!
You've those crappy little half round stainless steel doeys (like Perko back then) that sit on the stemhead casting??? http://www.perko.com/catalog/categor...rs/product/76/
They are definitely screwed in and generic replacements are available. 36 years is a good lifecycle for these. A nice new matched pair will be reliable and polish up your bow area.
msmith10 likes this.
rugosa is offline
post #9 of 20 Old 05-23-2013
Re: !@#$ 5200!!
You can buy a drill guide if it HAS to be precise... but they aren't worth it in my opinion. Drill around it if the area can be covered by the hardware and refill it all. OR, drill at high speed with light pressure and hold it really steady.
post #10 of 20 Old 05-24-2013 Thread Starter
Re: !@#$ 5200!!
Rugosa, that is the EXACT same light that I am dealing with. Would like to eventually go to LED.
5200 Bond misfits Gear & Maintenance 12 06-09-2013 03:54 PM
Painting 3M 5200 lancelot9898 Gear & Maintenance 1 04-02-2010 05:24 PM
3m 5200 NOLAsailing Gear & Maintenance 20 03-18-2009 07:48 AM
New Use for 5200 Neicy Gear & Maintenance 5 05-01-2008 02:12 PM
3M 5200 JDAM Gear & Maintenance 10 08-08-2007 09:14 PM
