Mildew - Page 2 - SailNet Community
 12Likes
post #11 of 23 Old 05-24-2013
snake charmer, cat herder
zeehag's Avatar
Re: Mildew
mold is toxic and causes respiratory distresses and coughs and nausea..yes mold is toxic. it is also easily cleaned with vinegar, screw the other expensive crap that has a regrowth situation after use due to lack of treatment of the spores. vinegar changes the p\h of the environment so it cannot regrow nearly as fast. try it and smile. it WORKS....nothing else did..lol...
but you guys need to learn the hard way about the value of vinegar, so use the bs you buy in stores, as you wont use the vinegar....lol...is what was used for decades before th e invention of bs substances that do not work a swell as does vinegar.
no. it doesnt leave a stink in the boat, silly.
and make sure you do not close boat up so there is no ventilation...another silly move. unless you have air conditioning, inwhich case, leave a small opening on opposite side/end of boat from air conditioning unit.....
JamesSkok and Seaduction like this.
formosa 41, cruising tropics
zeehag is offline
post #12 of 23 Old 05-24-2013
Re: Mildew
Zee,
Do you mix the white vinegar with water? etc?
lancelot9898 is offline
post #13 of 23 Old 05-24-2013
zeehag's Avatar
Re: Mildew
for stubborn stuff i use straight onto a cloth and wipe. for less stubborn, half and half mix..
full strength in the toilet to dissolve salt build up, then flush out and add oil of choice to lube it. must use toilet brush to clean porcelain, btw....lol
zeehag is offline
post #14 of 23 Old 05-24-2013
pdqaltair's Avatar
Re: Mildew
I like to think that as a tester and a chemist I'm open minded. In fact, I have some side-by-side tests running now for Practical Sailor.
* Vingar. Yes, I have a spray bottle on-board and it's usful stuff. You can read lots on-line. On a personal note I hate the smell of vingar and all perfumy products as well. I prefer no odor. But that said, vingar is an excelent weak acid cleaner that folks are comfortable with.
* Other traditional remidies include washing soda, baking soda, TSP, and borax; use these diluted in formulations I have listed in the attached link. Like vingar, they are rely on leaving a residue that prevents future growth in part by modifying the pH of the surface. There are other mechanisims too. Some of these apear to be very long lasting, as there is nothing to evaporate (acetic acid will dry in time).
Sail Delmarva: Borax: Stopping Mildew and Rot on the Cheap... and How the EPA Can Make Everything Complicated
The trick with vingar and these formulation is to dilute properly (more is NOT better) and leave a residue.
* There are many quatrenary amine products on the market. Most work, are relativly non-toxic, but don't seem to prevent return very well.
* We're testing some water-proof formulations for use on-deck. Gold Shied is one that I would love to hear feedback on.
* Surprisingly, most have learned that bleach is not too useful. It kills (if enough is used to bleach and damage fabrics) but doesn't prevent return (active ingredient quickly disipates). More irritating than actually "toxic" in the long-term sense, I still have little use for it inside. May help remove stains after the other cleaners have done their work. May not.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #15 of 23 Old 05-24-2013
Re: Mildew
Originally Posted by andrewoliv View Post
Anyone use Kanberra Gel? I am going to try that this weekend
You bet. Here is a thread I started here a couple of years back. Lots of info.
Kanberra gel
T37Chef and chef2sail like this.
Jeanneau 54DS
Minnewaska is offline
post #16 of 23 Old 05-25-2013
formerly posting as eryka
wingNwing's Avatar
Re: Mildew
Tea tree oil is the main active ingredient in Kanberra Gel. We tried the gel last winter. The gel seems to work best if you leave it to permeate an undisturbed area;if you keep opening to fresh air (like us who live aboard) you lose much of the advantage. Thus my suggestion for tea tree oil from a health food store above, diluted and sprayed directly onto surfaces it leaves a residue that lasts for months. Cheaper than the gel as well by a considerable margin. I have heard - but have not tried - that you can mix the oil into unflavored gelatin and make your own version of the gel.
Magnolia likes this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #17 of 23 Old 05-25-2013
Re: Mildew
Wing is right, the gel works best over the few days that we are closed up during the week. But it really does work. Amazing stuff.
I somehow doubt the rumor about gelatin. The consistency of Kanberra is almost toothpaste-like, but it all evaporates. I'm not sure the gelatin would.
Jeanneau 54DS
post #18 of 23 Old 05-25-2013
Owl
-OvO-'s Avatar
Re: Mildew
Also, gelatin is tasty for microbes and such, so you might just be fighting yourself by leaving a smear of it on all your surfaces.
-OvO- is offline
post #19 of 23 Old 05-25-2013
Re: Mildew
Originally Posted by northoceanbeach View Post
It's just awkward cleaning the v berth.
That's where the kid comes in handy.
ccriders is offline
post #20 of 23 Old 05-28-2013
Re: Mildew
I've found stuff called "Safe T Air" ...has tea tree oil in it and is cheaper than Canberra ... Canberra seems to be a bit more concentrated though.
The foam for all my interior cushions had a strange odor (can't quite nail down what the source was since it is from Prior Owner's time in the boat). This spring I put the foam in my van with Safe T Air for a week ... odor is gone!
RonRelyea is offline
Gelcoat Mildew-I'm so sick of gelcoat mildew bwindrope Gear & Maintenance 45 11-15-2015 04:28 PM
Mold and Mildew Sailor Dale MacGregor 5 02-03-2014 06:56 AM
mildew neophyte2006 Boat Review and Purchase Forum 12 11-29-2009 09:27 PM
Mildew wind_magic General Discussion (sailing related) 13 05-27-2008 05:28 AM
mildew prevention BrianConley Gear & Maintenance 2 10-25-2001 09:13 AM
