Wood work, bottom paint, keel bolts on Pearson 26 - Page 3 - SailNet Community
 1Likes
post #21 of 22 Old 06-16-2013
Senior Moment Member
SloopJonB's Avatar
Re: Wood work, bottom paint, keel bolts on Pearson 26
Originally Posted by mainer24 View Post
Oh-also, stripping/scrapping didn't work so well on the kell that has a lot of bumps and is not flat enough. I found a sandblaster for rent and it looks like it would be perfect for the cast iron. Once down to the bare metal and the rust removed, would Interpro 2000 be ready to be applied or is there a better thing to keep corrosion away and prime for anti fouling paint ? Not a lot of DIYers around in my town.. Thanks for all the help !
Definitely sandblast the keel, then immediately solvent wipe it and coat it with epoxy resin. This has been discussed in detail on the link below.
Shark 24 Keel
SloopJonB is offline
post #22 of 22 Old 06-19-2013 Thread Starter
Thank you ! Sandblaster rental was more affordable than expected (incl. delivery of the compressor), getting ready to clean these bumps and rust patches before applying the new barrier coat. Tech. Service from manufacturer was very helpful and said new barrier on hull can be applied on old one as long as it is sanded and solvent cleaned !
mainer24 is offline
Tags
wood hatch board pearson
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 12:56 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
keel clean up and bottom paint hobie61 Gear & Maintenance 1 04-30-2009 07:51 AM
Questions: Bottom paint prep work for trailer boat venturousviking Gear & Maintenance 22 04-23-2008 10:48 AM
