-   -   Climbing mast using Prussik (http://www.sailnet.com/forums/gear-maintenance/99828-climbing-mast-using-prussik.html)
THEFRENCHA 05-24-2013 08:04 PM
Hello
Does anyone has links to video showing how to climb mast with a system using Prussik ? Knots.
Specially for a large and 65 ft tall mast like I have
I once saw a video with a French guy doing a demo and would like to try It was very efficient, did not slide and he could work on top of the mast
I sail mostly solo so the bosun chair is of no use, tried the mast ladder but did not work for me and the ATN system is way too expensive !
Thanks
Frogwatch 05-24-2013 09:16 PM
Re: Climbing mast using Prussik
Check caving videos for people using a "Frog" system using prusiks instead of mechanicals.
It will require a chest knot and a leg knot.
Minnewaska 05-24-2013 10:00 PM
I wouldn't do it, but you'll need to tie two of them. One for your legs and another for your chest. You essentially step on the lower loop, stand up, push the one attached to chest as high as you can, hang from it, then pull the lower one up until your legs are bent as high as possible, stand up and repeat. Miserable!
I prefer that the prusik knot be used as a safety to prevent accidental descent, rather than climb with it. If you're single handed, mast steps are a good idea. Again, the prusik can be your safety.
SlowButSteady 05-24-2013 10:09 PM
Ropes? Who needs ropes?
<iframe width="420" height="315" src="http://www.youtube.com/embed/n1nkIc5ryPM" frameborder="0" allowfullscreen></iframe>
Frogwatch 05-24-2013 10:35 PM
It's easy, I've climbed thousands of feet or rope in caves and my own mast many time with such a system.
PaulinVictoria 05-25-2013 12:16 AM
Key thing with a prussic is to make sure that the ratio between the diameter of your prussic line and the line you are climbing is correct, if your prussic is too thick then it won't grip. I've used them for years in rock climbing, and been up the mast a couple of times, personally I'd trust them over a mechanical system.
It's easier if the line you are climbing (typically a halyard) is held fairly taught.
Joel H. 05-25-2013 01:03 AM
Personaly, I would invest in a second generation Petzl GriGri at minimum, then use a prusic on a footloop to climb the main (the GriGri locking in the gain), and a prusic on the Jib Halyard as backup.. FWIW
CHEERS,
JOEL H.
jrd22 05-25-2013 01:32 AM
A couple of ascenders make the climb easier than prussics. Second the rec for a Gri Gri.
The system works well but not necessarily easy unless you are in good shape (I'm 62 and it's a workout getting up our 55' mast).
Frogwatch 05-25-2013 02:18 AM
OK, I admit, all my prusik climbing was over 20 yrs ago but I really did climb over 1000' on prusiks from Golundrinas (deepest pit in the world). Still, prusiks are so cheap, basic and easy AND they work on wet muddy rope when mechanicals do not.
THEFRENCHA 05-25-2013 10:13 AM
Found the video
Check out this video on YouTube:
In French but easy the black liner is a tire for bicycle
Seems to work easily What do you think
