sail part, what is this called? - SailNet Community
 1Likes
  • 1 Post By zz4gta
post #1 of 9 Old 05-24-2013 Thread Starter
Sootydan's Avatar
Question sail part, what is this called?
What is the small line and "plastic cleat" called and used on sails like the one in the picture? How is it used? Thanks
http://www.sailnet.com/forums/member...2-jib-clew.jpg
Sootydan is offline
post #2 of 9 Old 05-24-2013
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Re: sail part, what is this called?
I think this is a leech line used to adjust the shape of your leech
Bill-Rangatira is offline
post #3 of 9 Old 05-24-2013
Yup,.. leech or foot line depending on what edge we're looking at. If that edge tends to flutter you can tension the line to stop it.. if it's over-tightened the leech will have a distinctly 'hooked' profile that is not helpful. Old sails will tend to flutter but also tend to hook when the line is tightened enough to stop the flutter. If that's happening they are probably due some minor surgery.
Faster is online now
post #4 of 9 Old 05-24-2013
MarkofSeaLife's Avatar
Dock
Don't put too inch tension on a leach line... They are not normally embedded in a fold (hem) of Dacron but in a fold of the UV cloth. It's got little strength unless new and the line can easily unzip the whole hem from tootsie to tippy top.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #5 of 9 Old 05-24-2013
One of None
deniseO30's Avatar
On my boat, it's just not long enough! I've yet to catch any leeches! but then I can't sail in swamps with 5 draft.
My last project!
deniseO30 is offline
post #6 of 9 Old 05-24-2013
pauloman's Avatar
folks above are right - making tigher adds camber to the sail - more shape. As wind picks up you let our for a flatter sail. More important is luff tension which controls location of 'curve' - tighter moves it forward, i.e. first gear
pauloman is offline
post #7 of 9 Old 05-24-2013 Thread Starter
Sootydan's Avatar
Thanks everyone for all the great info!!
Sootydan is offline
post #8 of 9 Old 05-29-2013
I don't discuss my member
zz4gta's Avatar
The leechline has nothing to do with camber of a sail. It's there to eliminate the flutter of the leech. It should not be used to shape the sail.
MarkofSeaLife likes this.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #9 of 9 Old 05-29-2013
The most female moderator
Donna_F's Avatar
Dock
Here is a SailNet article that describes it:
Leech Line
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
The Following User Says Thank You to Donna_F For This Useful Post:
Sootydan (05-29-2013)
Can't remember what this part is called jaschrumpf Gear & Maintenance 5 05-13-2009 06:39 PM
What is this sail called... XTR Gear & Maintenance 15 03-30-2007 05:16 PM
