Diameter of Diesel Water Exhaust Pipe - SailNet Community
post #1 of 9 Old 05-25-2013 Thread Starter
vtsailguy's Avatar
Wonder if someone can help me here....
I am connecting up a hot water heater. The current tubing from the diesel for the water exhaust is 3/4". I have a bunch of 1/2" tube lying around to run to the heater's exchanger.
Does it matter to the engine to step down to a smaller size tube, or is it important to keep to the 3/4" (i.e. have to by more tubing).
Three mini-pirates scour the Caribbean Seas with stops for ice cream and legos
Latest blog post:
vtsailguy is offline
post #2 of 9 Old 05-25-2013
sailvayu's Avatar
Re: Diameter of Diesel Water Exhaust Pipe
I would stick to the 3/4" to reduce back pressure on your pump. you are adding a longer line with more connection this will add some resistance in and of itself. That said you should be using the coolant side of your engine water not the raw water. Most water heaters are not designed to have raw or salt water in them. It works but you will be replacing the heater every 4-5 years if you do.
Capt. Wayne Canning, AMS
sailvayu is offline
post #3 of 9 Old 05-25-2013
One of None
deniseO30's Avatar
Actually.. I believe most WHs are 1/2" heat exchanger connections. the "loop" from the engine would be circulation of coolant rather then actually pumping. My boat, the lines are 7/8 ID and reduced to 1/2" and it works too well!
My last project!
deniseO30 is offline
post #4 of 9 Old 05-25-2013
BarryL's Avatar
Hello,
I'm confused. Is your engine fresh water cooled (has coolant) or raw / sea water cooled? If it is raw water cooled I don't know if it will get got enough to heat the water tank. Also, if your boat is in salt water i don't believe the water heater is designed for salt water.
If the engine is fresh water cooled then the water heater gets connected to the engine coolant, not the sea water / raw water pump. The connection should be:
engine block water OUTPUT to water heater input, water heater output to engine heat exchanger input, engine heat exchanger output to engine block input.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #5 of 9 Old 05-26-2013
Stu Jackson's Avatar
What's the connection size at the heater? That's the size I'd use, and only make it smaller to connect at the engine. For freshwater cooled (i.e., heat exchanger) engines, the take off for the heaters is usually at/below the thermostat and back to the freshwater coolant pump, and NOT on one of the lines to the HX.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #6 of 9 Old 05-26-2013 Thread Starter
vtsailguy's Avatar
Originally Posted by BarryL View Post
I'm confused.
Me too
Thanks to all these posts guys, it wasn't occurring to me that the hose I was seeing IS the closed loop for coolent. It's not raw water cooled.
So it sounds like I can just tap into that loop and run to the exchanger on the water heater., with no real issue with 1/2".....
Latest blog post:
post #7 of 9 Old 05-26-2013
As Stu indicated there's a 'standard' tie-in point for HW heater circuits. It would be wise to find out manufacturer's recommendations - you want the loop to be 'driven' not flow neutral.
Faster is offline
post #8 of 9 Old 05-26-2013
What engine do you have? Might help us to help you.
post #9 of 9 Old 05-27-2013 Thread Starter
vtsailguy's Avatar
Volvo Penta MD2030 29hp
Latest blog post:
Volvo Penta MD5 Exhaust Pipe Elbow GMC Diesel 13 04-01-2013 11:30 AM
Insulating the diesel heater exhaust pipe SailingAlaska Gear & Maintenance 6 10-22-2010 12:10 PM
New Exhaust Pipe Questions - Universal 5411 montenido Diesel 1 07-23-2009 03:52 PM
Diesel Exhaust Hose/Pipe 1970Columbia34 Gear & Maintenance 3 05-12-2009 07:34 PM
Diesel exhaust- water? MBesant Gear & Maintenance 26 07-18-2007 06:19 AM
