Cleaning old gas/varnish/chunks out of tank? - SailNet Community
post #1 of 4 Old 06-27-2004 Thread Starter
Is there any good way to clean a tank without removing from boat? It sat for about 5 years and clogged the filter and carb immediately. I drained it through a clear hose and even without a filter had to bang the hose constantly to keep the finger nail sized particles moving.
Joe
JoeTrecker is offline
post #2 of 4 Old 06-29-2004
i just had my tank cleaned by the yard and basically they vacuum up the fuel and run it over and over again thru large filters taking care to get all the bits at the bottom, sides, and in the corners of the tank. it took several hours and was somewhat costly given the amount of labor time involved. you might be able to rig up a similar device? or perhaps rent one from somewhere?
hamiam is offline
post #3 of 4 Old 07-07-2004 Thread Starter
Thanks Hamaim,
Any thoughts on throwing a gallon of parts cleaner in the tank and letting it slosh around for a couple weeks?
Joe
post #4 of 4 Old 07-08-2004
Probably not a good idea as you will never get rid of all of it.
hamiam is offline
removing orig water tank zeilfanaat Gear & Maintenance 8 14 Hours Ago 12:26 PM
Building a head tank Irwin32 Gear & Maintenance 6 11-05-2006 12:24 AM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 09:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 09:34 AM
Fuel tank algae freds Gear & Maintenance 6 12-20-2002 01:57 PM
