Sail tape not sticking - SailNet Community
post #1 of 11 Old 05-26-2013 Thread Starter
World Traveler
Hiroshimasunset's Avatar
Send a message via Skype™ to Hiroshimasunset
Hi,
We have just applied some Bainbridge Dacron Sail Tape to the luff chord of our mainsail, but it doesn't seem to be sticking very well. Does sail tape become more sticky after application? It doesn't seem like it will hold.
Any input from people with experience using sail tape appreciated!
B.
Hiroshimasunset is offline
post #2 of 11 Old 05-26-2013
Re: Sail tape not sticking
Sometimes if you clean the area very well with alcohol it may stick, however I've always had better luck getting it to stick where I don't want it.
Put some on a genny once where it was hitting the spreader, it came off on the end of the spreader and stayed there for a couple years.
capttb is offline
post #3 of 11 Old 05-26-2013
Are you trying to 'repair' the luff tape (ie the part that goes into the foil?) We've noticed problems sticking sail tape to any areas with heavy stitching, anywhere that's not really clean and possibly salty, but also the added bulk might cause problems sliding in the foil groove if that's what you're trying to do...
Faster is offline
post #4 of 11 Old 05-26-2013
MarkofSeaLife's Avatar
Dock
Sail tape is a useless expensive waste. And it doesn't stick!
I always have a litre tin of Contact Cement on board and some spare sail cloth and I stick the sail cloth on with contact cement.
It works well, its flexible.
I use it when using sail tape too.
Grab a can
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #5 of 11 Old 05-26-2013 Thread Starter
World Traveler
Oh, made a mistake...we are trying repair wear on the leech of the main. Does it take some time for the tape to reach maximum bond strength?
Thanks for the replies
post #6 of 11 Old 05-26-2013
That makes more sense, but now you're into an area with a heavy stitching pattern, which lifts the tape off the sailcloth and inhibits the 'stick'..
It won't cost a fortune to have a sailmaker repair the leech, and if it's an older it sail it may benefit from a wee 'tuck' anyhow. If the wear comes from spreader or shroud contact they could add a patch at the same time.
Faster is offline
post #7 of 11 Old 05-26-2013
snake charmer, cat herder
zeehag's Avatar
find good glue--not wood glue.
tape sail with good glue. might wanna ask a sailmaker about what kinda glue to buy for this..
sew the glued taped area all around the edges of tape with zig zag stitches. twice. not on top of each other.
then mebbe the sail tape might stick.
have fun...
when you are finished screwing up your sail, the sailmakers can still repair it, so it isnt a big deal to try to fix it first.....might just cost a tad more than if you didnt try too hard at home...
formosa 41, cruising tropics
zeehag is offline
post #8 of 11 Old 05-26-2013
JimsCAL's Avatar
I've used sail tape on the leech of my main and had good luck with it. Sticks like crazy and never came off even after several years of use. Love the stuff. Mine came from Defender. Highly recommended.
JimsCAL is offline
post #9 of 11 Old 05-26-2013
SchockT's Avatar
If it is not sticking to the cloth then either the tape is really low quality, or the sail has something on it preventing adhesion. Ask your local sailmaker for a piece of "insignia cloth". It should stick to any part of the sail. If you are sticking it to a stitched area you may need to rub a hard object on the tape to press it onto the cloth between the stitching.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #10 of 11 Old 05-27-2013
TQA
Bombay Explorer 44
TQA's Avatar
Hi,
B.
Maybe someone has sprayed Teflon or Silicon spray on the mast track and or sail.
Both will inhibit the stickum.
TQA is offline
Tags
sail repair , sail tape
Sticking Furler (Furlex) Ladyhawke2 Gear & Maintenance 8 04-17-2010 05:50 PM
Sticking mainsail fireman181 Gear & Maintenance 12 03-03-2008 09:51 AM
Sail repair - Tape or Sew? w/ pictures US25 Gear & Maintenance 19 08-01-2007 10:20 PM
Impeller is sticking. jr438234606 Gear & Maintenance 2 06-27-2006 12:13 PM
Sail..changing from hank on to luff tape gentlerain Gear & Maintenance 1 08-21-2002 02:40 PM
