Wire halyard through random block. - Page 2 - SailNet Community
 3Likes
post #11 of 14 Old 05-29-2013 Thread Starter
first sailed january 2008
northoceanbeach's Avatar
Re: Wire halyard through random block.
That's what was left after its through a clutch in the cockpit.
northoceanbeach is offline
post #12 of 14 Old 05-30-2013
While I have found wire halyards far superior for main and jib halyards , for a spinaker they are less justified, as a bit of stretch there is not a big problem. They would eliminate chafe tho. You would want the biggest diameter sheave you can use, and galvanized 7x19 wire to minimize metal fatigue and broken strands.Tuffnol or metal would last far longer for a wire halyard sheaves .
Brent Swain is offline
post #13 of 14 Old 05-31-2013
Aspiring to be a Mexican
sww914's Avatar
Originally Posted by paulk View Post
A white sheave sounds like nylon. A wire halyard will likely cut through it like.... butter. The ONLY reason to have a wire-to-rope halyard on any boat in 2013 would be for a museum display of a boat from the '70's or before. Modern synthetic fiber line is actually stronger than the same diameter wire, and stretches (the reason wire was originally used) less than wire. Splicing wire-to-rope costs so much that even an expensive extra-low stretch synthetic full-hoist halyardoften ends up being cheaper than a wire/rope halyard. The full-hoist line can also be reversed, doubling the life of the halyard. We replaced our wire/rope halyards more than ten years ago, and haven't needed to reverse them yet. Even if your wire to rope halyard was given to you as a present, I would take it off and go with a low-stretch synthetic line. Besides wearing through the spinnaker crane block, the wire is going to develop soldiers that will cut the hands and fingers of foredeck crew, as well as possibly snagging sails. It's simply not worth it.
I agree with you but there is one other reason to use wire/rope halyards. Because I got 3 brand new 100'ers for $75.00. Not each, for the three of them.
sww914 is offline
post #14 of 14 Old 06-01-2013 Thread Starter
I have galvanized 7x19.
I'm glad some people see the value in wire halyards. Before i got them I read some of your previous posts on your pacific crossings with them Brent.
Wire Halyard Winches tdw Gear & Maintenance 15 03-19-2014 01:57 AM
spirit 23 jib halyard block ? Southron Spirit North American Yachts 5 09-21-2012 09:41 PM
Jib halyard ends with a 4:1 block??? village idiot Gear & Maintenance 10 11-02-2011 09:40 AM
Wire halyard davidpm Boat Review and Purchase Forum 7 04-05-2010 09:48 PM
Wire / Rope Halyard RumorHazit26 Gear & Maintenance 14 08-27-2007 10:55 PM
