Shaft Through-hull Leak - Page 2 - SailNet Community
 6Likes
post #11 of 15 Old 06-21-2013 Thread Starter
Re: Shaft Through-hull Leak
Nice to see another P28-2 owner!
Mine is the shoal draft version, and the hull design suggests the through hull is original, though you're absolutely right that the gobs of sealant suggest a bad repair by a PO...
The boat's out of the water now, and looking from the outside confirmed that this was indeed a through-hull style log. Now the question is where to find a new one.
Online I only saw buckalgonquin, but they don't sell direct.. If you where it might be available it'd be terrific.
Also, could you please share the p28forum image url (I'm also on that group)
Thanks!
ahalfon is offline
post #12 of 15 Old 06-21-2013
Senior Smart Aleck
jameswilson29's Avatar
Hamilton Marine sells Buck Algonquin. Perhaps you could build your own fiberglass shaft log and install in its place.
jameswilson29 is offline
post #13 of 15 Old 06-21-2013 Thread Starter
Great to meet another p28-2 owner!
Mine is the shoal draft version, which may have a different log arrangement.
It's out of the water now, and looking from the outside confirms it's a through-hull.
It looks original, but as you said the gobs of sealant suggest a bad repair by a PO..
I'm going to replace it altogether, and am trying to find the right part.. any help would be greatly appreciated.
Could you also please post a link to that image on the p28forum (I'm also a member)
Thanks!
Amir
ahalfon is offline
post #14 of 15 Old 06-21-2013 Thread Starter
Thanks for the tip!
Sorry about the double post... user error
ahalfon is offline
post #15 of 15 Old 06-21-2013
no longer reading SailNet
Alex W's Avatar
I responded with the photo link on the p28forum, since you have to be a member to see it (and I saw your question there first).
Fisheries Supply can get the B/A part.
Alex W is offline
Shaft seal leak beanctr56 Gear & Maintenance 15 03-01-2011 10:00 AM
Shaft Log Leak (Pics) nk235 Gear & Maintenance 31 05-06-2009 06:32 PM
Tricky Shaft Log Leak Repair JonG Gear & Maintenance 7 04-27-2009 09:00 PM
Leak in Drive Shaft for Inboard Trescool Gear & Maintenance 11 09-03-2007 10:13 AM
Shaft Log Leak R33 Gear & Maintenance 4 06-26-2002 10:28 AM
