pump for head won't pump out - Page 2 - SailNet Community
post #11 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
Re: pump for head won't pump out
[B]Pump is supposed to be self priming to 5 feet heres a link to the type pump i have
]Jabsco Self-Priming Macerator Pump - iboats
Sootydan is offline
post #12 of 14 Old 05-29-2013
Crealock 37
sailak's Avatar
Dock
Originally Posted by Alex W View Post
Sorry, I can't help you with that. I have no experience with macerating pumps.
Note that it is illegal to use them in coastal waters in the US. It looks like you are located in Mass.
Ummm, no you can use macerator pumps anywhere for anything. What isn't legal is discharging sewage overboard.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #13 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
It is illegal to discharge or empty the contents of your boat's holding tank in U.S. territorial water ( within a three-mile limit). Some boats are equipped with a "Y" -valve that allows for the direct discharge of raw sewage. This valve can only be used outside the three-mile limit. Coast Guard regulations require that the "Y"-valve must be secured in the closed position (by padlock, non-resealable tie, removal of handle or other physical barrier) when the boat is within three miles of shore. Boaters can be fined for non-compliance.
Sootydan is offline
post #14 of 14 Old 05-30-2013 Thread Starter
Sootydan's Avatar
ITS FIXED! Well I took the pump apart and reassembled it, I don't think the retaining nut was secured correctly. It works great now , I was about to re-plumb the whole damn thing today lmao Thanks for all the replies
Sootydan is offline
the head pump is harder to pump ekenna Gear & Maintenance 6 06-03-2010 09:28 AM
Priming Head Pump Out Hose L124C Gear & Maintenance 11 04-23-2010 12:21 PM
Head pump not working hooligan6a Gear & Maintenance 4 12-25-2009 06:48 PM
Head Mate HAND Pump...not! razwrld Gear & Maintenance 5 08-01-2008 05:39 AM
Will you pump out my head? Jotun Gear & Maintenance 61 04-28-2007 12:21 AM
