pump for head won't pump out - SailNet Community
post #1 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
The boats head has a hose to the holding tank, the tank then has a drain hose going to a " Y" valve, one side goes to a deck fitting for pump out, the other goes to a Jabsco macerating pump which vents out the through hull fitting to the ocean. The Y valve is turned correctly to pump out the tank but it can,t seem to pump out. Wondering if the pump isn't strong enough ? I dropped the pump down lower but it barely pumps any water out. There is a vent loop on this side also which makes it harder to pump up and out I guess. So after all my work am I screwed? Lol
Sootydan is offline
post #2 of 14 Old 05-29-2013
no longer reading SailNet
Alex W's Avatar
Re: pump for head won't pump out
The Y-valve is probably broken. It was on my Pearson 28-2 when I purchased it.
You can test this by replacing the Y-valve temporarily with a 1.5" barbed splice. That is a couple of dollars vs $50ish for a new Y-valve. I didn't have a splice handy when I figured this out, but was able to hack it using duct tape to splice the two lines, then pump it out. Obviously that is not a good long term solution.
Alex W is offline
post #3 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
[B]HThanks for the reply, The Y valve is brand new, , everything is new actually, I can blow back through the hose( only water has passed though it so far so its clean) so its not blocked. the pump gets water up to it then cannot pump out, about 4 feet of 1 1/2 inch hose to pump then one inch out of pump to 1 1/2 again through vent loop and out.
[/Bhttp://s1351.photobucket.com/user/Sawltydan/media/null_zpse122f4de.jpg.html?sort=3&o=0http://s1351.photobucket.com/user/Sawltydan/media/null_zpsbedec434.jpg.html?sort=3&o=1
Sootydan is offline
post #4 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
Here';s some pics of what i have fpr the pump set uphttp://s1351.photobucket.com/user/Sawltydan/media/null_zpsbedec434.jpg.html?sort=3&o=1
Sailing Photo by Sawltydan | Photobucket
Sootydan is offline
post #5 of 14 Old 05-29-2013
Alex W's Avatar
Having you tried another pump? They do break, and when one is clogged it behaves as you are describing. My marina has 3 or 4 of them.
At my old slip I'd have to go to the next marina (about 2 miles away) if the first one had a broken pump.
Alex W is offline
post #6 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
If it id broken ill be mad, its brand new , never used until today lol, ill take it out and test it with a bucket of water to make sure it pumps
Thanks
Sootydan is offline
post #7 of 14 Old 05-29-2013
Alex W's Avatar
Wait, is the pump that is failing the one to your macerator pump, or the one for the dockside pump-out?
I've never tested my macerator pump, it would take me 2 long days of sailing to even get to waters where it is legal for me to do so.
Alex W is offline
post #8 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
The pump Im using is a Jabsco macerating pump, only pump im using, plumbing is Head to tank, tank out to Y valve, Y valve either straight to deck fitting for dockside pump out ( no pump involved on boat) or Y valve to jabsco pump to anti-siphone vent to through hull fitting.
Sootydan is offline
post #9 of 14 Old 05-29-2013
Alex W's Avatar
Sorry, I can't help you with that. I have no experience with macerating pumps.
Note that it is illegal to use them in coastal waters in the US. It looks like you are located in Mass.
Alex W is offline
post #10 of 14 Old 05-29-2013 Thread Starter
Sootydan's Avatar
yes you have to be outside the limit (3 miles) before it can be used, I have a holding tank and deck pump-out fitting for inside the limit with a locking Y valve, Thanks
Sootydan is offline
the head pump is harder to pump ekenna Gear & Maintenance 6 06-03-2010 09:28 AM
Priming Head Pump Out Hose L124C Gear & Maintenance 11 04-23-2010 12:21 PM
Head pump not working hooligan6a Gear & Maintenance 4 12-25-2009 06:48 PM
Head Mate HAND Pump...not! razwrld Gear & Maintenance 5 08-01-2008 05:39 AM
Will you pump out my head? Jotun Gear & Maintenance 61 04-28-2007 12:21 AM
