Shower Sump Won't Pump - SailNet Community
post #1 of 16 Old 05-29-2013 Thread Starter
Learning Fast
Pearson 32, from 1982. Has sump pump for shower with manual pull switch in the head. Bought boat 4 yrs ago; the sump would pump, but we never used the shower. Now the sump motor groans & whirs a little, but the sump won't pump. Possibly related (but I doubt it), the sink in the head no longer drains. From the boat manual, I think there are separate thru hulls for each. For this thread I'm looking for advice:
1. do I have to wait until a haul out and have a boat yard do this?
2. dare I unscrew the floor cover in the shower and look for clogged filters and other stuff to fix myself? and is there a site with step by step instructions?
3. is there regular sump maintenance I should have been doing? Like vinegar down the drain, etc?
4. should I consider some form of pipe snake to push through and clear the through hull valve in either the sink or the sump?
Thanks in advance for your assistance!
Outrageous is offline
post #2 of 16 Old 05-29-2013
Re: Shower Sump Won't Pump
This is something you can definitely check out yourself. I bet the problem will be very obvious once you take up the cover.
knothead is offline
post #3 of 16 Old 05-29-2013
Best Looking MALE Mod
Cruisingdad's Avatar
It is not unusual for my pump to get an air lock. This happens in centrifugal pumps when the it has air between the outbound Thull and the pump. If you have a diaphram pump, ignore this. But I fix a vapor lock by putting a water hose to it on low pressure and pushing water through until it is flowing freely. If you cannot push water through freely, you know you have some kind of block. Could be a hair clog... but try using a wire pulling snake to check. It is a long plastic line that we use to pull wires (snake) with. I like that because you can run it through without breaking anything.
Same with the sink, but it should be an easy fix (again with the plastic snake).
Does that make sense?
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #4 of 16 Old 05-29-2013
Fresh water refugee
katsailor's Avatar
Your sink may have a through hull fitting, Check to see if it is closed. If the pump is running but not pumping it may need to be replaced. How much water is in the sump?
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #5 of 16 Old 05-29-2013
jsaronson's Avatar
ccould be a clogged hose or filter, bd pump or any combo. time to get dirty!
jsaronson is offline
post #6 of 16 Old 05-29-2013
chef2sail's Avatar
Clogged filter creek probably. Some pumps have hands on pulleys which come off the tracks internally. Some also have impellers. Check them.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #7 of 16 Old 05-29-2013
You may be surprised by what a screw driver and a pair of sharp eyes can do.
Capt Len is offline
post #8 of 16 Old 05-30-2013 Thread Starter
Learning Fast
Capt Len:
Yeah, I've often surprised myself with a screwdriver and pair of sharp eyes. That's why I'm asking you Experts for advice first
katsailor:
1. through hull in bathroom sink thinks it's open, but it's possible the handle no longer operates the ball valve and it needs replacing.
2. there's no water currently visible because we sponged it up.
Cruisingdad:
I'm off to find a plastic snake suitable for the boat. Recommendations welcomed!
Thanks so far. Will update with what works (and doesn't).
post #9 of 16 Old 05-30-2013
no longer reading SailNet
Alex W's Avatar
You should follow the hose coming out of the shower sump and see where it goes. On my Pearson the shower sump goes to a diaphram style pump which then pumps it out a through hull on the transom (well above water line). The sink in the head goes through it's own through hull that runs out of the side of the boat (just below water line).
Alex W is offline
post #10 of 16 Old 06-19-2013 Thread Starter
Learning Fast
Since these posts, I've tried to take off what I trust is the cover plate for the shower sump. I've removed the 4 stainless screws and tried various spanner wrenches etc. to turn the plastic drain hole - all of which I think I'm supposed to do. The hole won't move (and I'm not forcing it). There is also sealer around the cover, which I'm prepared to scrape out if it turns out that removing the hole doesn't just reveal the source of the clog/problem. BTW, we've owned the boat 4 years but never showered in it; however the boat is 30 years old, so likely someone did. Just not clear what we did that might have suddenly clogged it.
I did some online research about Rule, Attwood, and Whale shower sumps and can't find any pictures of something like what I have.
At any rate, attached are picks of the cover and hole, and welcome your advice before I damage something by trying to do too much the wrong way...
Shower sump pump failure nika44 Gear & Maintenance 11 06-24-2013 08:22 PM
Shower Sump Pump Bump Gear & Maintenance 10 10-16-2011 05:57 PM
How-To for Shower Sump tomperanteau Columbia & Coronado 0 05-17-2011 03:42 PM
Endeavour 40 shower sump eskimo1941 Announcements and Suggestions Box 3 09-18-2009 08:06 PM
Air Cond to shower sump? Necessary or not Pamlicotraveler Gear & Maintenance 8 07-28-2008 04:12 PM
