Cal 28 Teak Toe Rail - SailNet Community
post #1 of 5 Old 05-29-2013 Thread Starter
The teak toe rail on my Cal 28 MkII is mounted on a one inch piece of plastic that runs from the bow to the stern on both sides of the boat. The plastic is broken in several places and water is getting in the boat.
Where can I buy new plastic and what is the best way to remove and replace it?
Thanks
Walker86 is offline
post #2 of 5 Old 05-30-2013
Senior Moment Member
SloopJonB's Avatar
Re: Cal 28 Teak Toe Rail
Thanks
Pics would help.
SloopJonB is offline
post #3 of 5 Old 05-30-2013
JimsCAL's Avatar
I have the same construction on my Cal 33-2. I think you are going to have a tough time finding an identical replacement. And it will be a huge job, requiring removal of the entire toerail, etc. You could certainly just reinstall the toerail with LIfecaulk or something similar in place of the gasket.
Are your sure that is where the water is coming from? Not from stanchion bases or other leaking fittings? You certainly don't want to go to all that trouble and find out its coming from somewhere else.
JimsCAL is offline
post #4 of 5 Old 06-05-2013 Thread Starter
I won't remove the toe rail without first checking the stanchions and and rigging for leaks. I enclosed some pics of the toe rail with the plastic (PVC??) mounting. The starboard side has the 3 to 4 inch piece missing as a result of a collision, I suspect. Where does one find a piece that serves as a mounting for the teak rail that runs the length of the boat?
Any suggestions on how to make the repair?
Thanks
Walker86 is offline
post #5 of 5 Old 06-05-2013
Unkle Toad's Avatar
Are you in the southern hemisphere? those look upside down to me here in the puget sound
Unkle Toad is offline
Teak Rub-rail hubblect Gear & Maintenance 5 06-17-2011 10:16 PM
Help removing teak toe rail saladpe Gear & Maintenance 10 11-01-2010 06:35 PM
Teak toe rail repair drlove Gear & Maintenance 1 08-26-2009 06:25 PM
repairing teak rub rail LookingForCruiser General Discussion (sailing related) 3 04-01-2009 04:20 PM
teak rub rail adamlaw Gear & Maintenance 2 12-30-2007 10:32 PM
