Raised chainplate deck fittings question - SailNet Community
 1Likes
  • 1 Post By SloopJonB
post #1 of 5 Old 05-30-2013 Thread Starter
budvar's Avatar
I'm sure to get a wide variety of responses, from why would you do that? etc.
I have my mast down, have new standing rigging waiting to be raised. Decided to raise the chainplates. Have polished the stainless hardware, and re-epoxyed the chainplate hole site.
Question: In using the modeling clay (as a form) such as in "this old boat" should I sand the gelcoat down to the fiberglass layer? I am using epoxy resin. Or will the epoxy stick to the gelcoat.
Thanks!
budvar is offline
post #2 of 5 Old 05-30-2013
tommays's Avatar
Re: Raised chainplate deck fittings question
Yes I would sand to glass so you get the best bond
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
budvar (05-30-2013)
post #3 of 5 Old 05-30-2013
Señor Member
PorFin's Avatar
Yep -- I'm in full agreement with Tom.
Here's the reasoning. Gelcoat is simply polyester resin thickened with talc; it has little inherent structural properties. If you have that layer between the original glass and your epoxy risers, then you have two bonds that could fail (gel to glass; epoxy to gel) instead of just one.
For a "do it right the first time" solution, sand down until you hit the glass and build your risers from there.
________
'85 BYB Vagabond 39
PorFin is offline
The Following User Says Thank You to PorFin For This Useful Post:
budvar (05-30-2013)
post #4 of 5 Old 05-31-2013 Thread Starter
budvar's Avatar
Thanks! One other question. So the new chainplate mount is basically epoxy resin, with some filler. The old screws for the chainplate cover looked like wood screws and didn't go very deep. Can I still use the wood screws on the raised epoxy mount? I would guess you predrill a hole slightly smaller than the screw. Other choice in screws? Tap it? Sorry, I did try to research this, couldn't find much.
Thanks again,
Chris
budvar is offline
post #5 of 5 Old 05-31-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by budvar View Post
Thanks! One other question. So the new chainplate mount is basically epoxy resin, with some filler. The old screws for the chainplate cover looked like wood screws and didn't go very deep. Can I still use the wood screws on the raised epoxy mount? I would guess you predrill a hole slightly smaller than the screw. Other choice in screws? Tap it? Sorry, I did try to research this, couldn't find much. Thanks again, Chris
I'd use self tapping screws. Another option is to tap threads into the epoxy and use machine screws - there is no real stress on those fasteners so the epoxy threads will hold no problem.
Self tappers will work as well and are less trouble to install though.
Forget wood screws - they are for wood.
budvar likes this.
SloopJonB is offline
The Following User Says Thank You to SloopJonB For This Useful Post:
budvar (05-31-2013)
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 05:48 PM
Where can I get metric sized cleats & deck fittings? Pamsboat Announcements and Suggestions Box 1 05-24-2010 10:35 AM
Deck Repair - how to cut hole for chainplate KindOfBlue Gear & Maintenance 5 06-17-2009 03:14 PM
Shim for deck fittings question StillInShock Gear & Maintenance 2 07-01-2007 10:35 PM
Leaky Deck Fittings - Bah! SEMIJim Boat Review and Purchase Forum 37 06-28-2007 11:02 AM
