1972 tartan 30 - Page 9 - SailNet Community
 17Likes
post #81 of 99 Old 06-18-2013
Moderator
Jeff_H's Avatar
Re: 1972 tartan 30
I bought Synergy without a sail trial. I normally don't recommend doing that (especially you are buying the boat with every penny that you have.) In my case money was put in escrow to cover the transmission and the depth sounder until we could test them, and then retuirned when they turned out to be in good shape.
We tested the engine by putting the engine cooling water intake hose in a bucket and ran a garden hose to the bucket to keep it full and so we were able to run the engine for about 15 minutes or so and look for issues.
Originally Posted by Alex W View Post
4' of soft decks and the rudder having elevated moisture levels aren't major problems?
The Tartan 30 and similar Yankee 30 do have good engine access.
I would say that those are comparatively minor problems on a forty year old, $9,000 Boat with a diesel and decent sails...
Jeff_H is offline
post #82 of 99 Old 06-18-2013
tommays's Avatar
Re: 1972 tartan 30
[IMG]DSC_0009[/IMG]
First i sail on a boat with a 12 year old saltwater used Beta and that motor has clearly had TONS of water dripped on it OR the boat flooded at some point and rusted up the rear main seal causing the oil leak
DSC_0006
It is pretty common for stored boats to flood form snow over the winter and do something like this and the green wood mold is a sign of much wetness
Paying to Pull the motor to fix oil the leak is a budget buster and the boat cant be used like THAT
I tend to agree you will not do much better one question is how the survey will be written up and how your insurance would interpret it
For example if he says the wet area of deck is delaminated they could mandate a repair before the boat can be used
They would most certainly take issue with original standing rigging
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #83 of 99 Old 06-18-2013 Thread Starter
Re: 1972 tartan 30
Just to add, the oil level is right in the middle of high and low, not under low. No idea of where he filled it to.
abrahamx is offline
post #84 of 99 Old 06-18-2013
One of None
deniseO30's Avatar
Re: 1972 tartan 30
Just a note about oil leaks.. there have been a few discussions about crankcase breathers, blockage of and installed wrong.
Jus sayin
My last project!
deniseO30 is offline
post #85 of 99 Old 06-18-2013 Thread Starter
Re: 1972 tartan 30
OK, I am about to go mad. What is, no WTW is this stuff about crankcase breathers? Flippin A! I do agree about the engine apperance. Was the first thing I noted. Even mentioned it to the surveyor. Mentioned that it was more dirtier than what I was accustomed to and he just shruged it off.
abrahamx is offline
post #86 of 99 Old 06-19-2013 Thread Starter
Re: 1972 tartan 30
I suppose the crankcase breather is a possibility. It it posssible that the owner filled the oil to half way between full and under full and it has not leaked any oil while on the hard. The oil in the bilge was dirty I am pretty sure. I do agree with the engine appearance. Just not sure how it would get wet being in the middle of the cabin unless it was dripping down the mast. The boat was nicely shrink wrapped. I guess its worth $200 to find out what the deal is.
abrahamx is offline
post #87 of 99 Old 06-19-2013
blutoyz's Avatar
Re: 1972 tartan 30
You seem cool with all the other issues on this boat so as was posted already run it on the hard to identify the source of the oil.
You will have to clean it up first but all you will have invested is some time, the oil in the bilge could be from a sloppy change...who knows.
blutoyz is offline
post #88 of 99 Old 06-19-2013
Chastened
Ajax_MD's Avatar
Re: 1972 tartan 30
At the very least, run the engine on the hard, using a bucket of water for cooling.
Since it's located in the middle of the cabin, you can easily observe the engine for excess vibration, leaks, smoke, etc. While the engine is running, shine a powerful light onto "mating surfaces" like the cylinder head, intake and exhaust manifolds, thermostat housing, injectors, water pump, heat exchanger...anywhere that something could leak a gas or fluid.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #89 of 99 Old 06-19-2013 Thread Starter
Re: 1972 tartan 30
I am trying to confirm but the survey from 06. Had the motor at 86 hours. A mechanic said its likely to have about 200 on it now. Hard to believe it could be shot. We shall see. Probably spring for the survey.
abrahamx is offline
post #90 of 99 Old 06-19-2013
Moderator
Jeff_H's Avatar
Re: 1972 tartan 30
It is hard to believe that it is shot unless it was run without oil, or cooling water at some point. Bad fuel and improper fuel filters can do a real number on the fuel injection system. (I once looked at a boat with a friend that the owner had removed the fuel filter from the system. When asked he said,"It was a pain in the neck, since it kept getting blocked up.") Injector parts are expensive even when bought at the farm store.
Jeff_H is offline
Tartan Yachts Wins Prestigious Awards For The New Tartan 4000 - PR Web (press release NewsReader News Feeds 0 01-23-2012 11:30 AM
tartan 41 1972 keel? jwjab Sailboat Design and Construction 7 08-15-2011 04:31 PM
1972 Cal T4 coldsteel Cal 7 02-03-2009 03:23 AM
1972 Cal 33 jkliegman Boat Review and Purchase Forum 2 03-11-2006 10:11 PM
1972 Aquarius 23'' Gid Gear & Maintenance 1 08-05-2002 03:50 PM
