Docking with a spring line questions - Page 5 - SailNet Community
 10Likes
post #41 of 48 Old 06-08-2013 Thread Starter
Re: Docking with a spring line questions
Hi all - I went back out to the boat and while I was able to get it to balance after it had "settled" by making sure the spring was tied aft of the widest part of the boat (it probably only narrows a couple inches from there to the stern) the first thing that happens as soon as the spring is tensioned, is that the bow wants to swing to port in to the dock (port tie)...and not just a little.
I did all this while I had a stern line tied so even if the bow swung hard toward the dock it wouldn't hit. No matter where I tied the spring (I started from the widest part and moved backwards, in all cases along the toe rail or stanchion base) as soon as tension came on it, the bow swung to port. In some cases it didn't go far enough to tension the stern line, in others it did, so it's definitely capable of hitting the dock even with the spring tied aft of the widest part of the boat with forward throttle and the wheel turned away (or any rudder position, I tried many.)
So it seems the sweet spot is not along the rail aft of the widest part of the boat. I'm thinking maybe I should move it inboard to one of the winches (or would that make it worse?) The other thing I thought was that the spring needs to be longer so it is cleated just behind the stern at stasis but I only have about a foot an a half left in front of the bow so I'm not sure that's the best idea. My genoa tracks and toe rails are solid so I'd have to invasively install something and I don't want to do that until I know something is going to work!
Any thoughts on this?
brianc is offline
post #42 of 48 Old 06-09-2013
Man, your boat acts funny. OK, one more idea. The profile of your boat is very full aft. So, try this.
Put fenders along the aft half of the boat on the dock side. Who care's if the aft side comes in cause the fenders will stop it, what you don't want is the bow to head towards the dock. Given the profile of your boat, even if you compress all the aft fenders, it will still sit pretty close to parallel to the dock. Then, try attaching a stern line only, and power forward. Make sure the stern line has a relatively steep angle to the dock (running to a cleat on the dock which is way behind where the boat will end up). If the bow comes out (away from the dock) too much, move the line marginally forward on the boat till it doesn't.
If the bow comes into the dock with just a stern line attached, you'll have the first boat I've ever seen that does that. But I've been surprised before
capecodda is online now
post #43 of 48 Old 06-09-2013
brianc
You may be over thinking.
The intent of the single mid-ship spring line is to be the first dock line to secure, which then provides some breathing room to secure the other dock lines.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #44 of 48 Old 06-09-2013
ASA and PSIA Instructor
Yes, as mentioned in my earlier post use right rudder and prop wash to line the boat parallel to the dock the doc and keep it so before you apply power to bring it into the dock. If the issue is that with your sail drive unit you don't have enough water flow past the rudder to give you control with right rudder then I think you're outta luck. Maybe another knock on sail drives...
Sent from my DROID RAZR using Tapatalk 2
sailingfool is online now
post #45 of 48 Old 06-09-2013
HANUMAN
RobGallagher's Avatar
The prevailing wind or current may still affect your boat, even if the spring line is balanced. It does not always work perfectly.
Also, keep experimenting. It may help to move that line inboard as you stated.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is online now
post #46 of 48 Old 06-09-2013 Thread Starter
capecodda - so yesterday I went back out, waited for most of the people/boats to head out for a fun race so as to cause myself the least embarrassment, and tried some more stuff. I went back to the standard midship spring line, tied a butterfly knot to make a loop at the correct length (or at least where the stern would be close to the cleat where the loop was attached) and ran the remainder of the line to the aft most winch, which is just slightly forward and inboard of the stern cleat, figuring that when the bow started to turn I could control it with the horizontal pull from the dock cleat to the winch. It turns out I tied the spring just slightly long so when I came in, dropped the loop over the cleat, the pressure came on to the winch-cleat line instead of the spring and the boat pretty much just nestled up to the dock, as you described. So...getting closer!! Do you see any issue leaving the spring and then hauling in the stern line using the winch as the boat gets further in to the slip? I like the idea of being able to use the length of the spring to get the line on the cleat earlier rather than waiting to get far enough in to loop the stern line. Anyway, progress is good ;-)
Ulladh - yes, I understand that, but with this boat, for whatever reason, when tension comes on the midships spring line, the bow dives in toward the dock and the stern swings out, potentially damaging me and my starboard neighbor.
sailingfool - I can get "control" with the propwash/rudder but only with a big burst of power. With my new neighbor being considerably bigger than my old neighbor, I need to be more careful so I'm hesitant to gun it like that if something were to go wrong.
brianc is offline
post #47 of 48 Old 06-09-2013
Brian,
If I understand what you did, I think it worked because you effectively had a more aft mounted spring line, attached to your winch or winch cleat. A winch if you can get a fair lead to the dock is certainly a nice place to attach a spring because it's well fastened to the boat, and you could use the winch to adjust it even under load. I knew a captain who operated a big boat with power winches this way, and it worked out nicely.
Singled handed, I've never found it "easy" to attach to a cleat on a float. With 2 people it's easy. Get the person with the spring line forward on your boat, and have them step off or loop the cleat way before the line gets taught.
Keep experimenting with attachment points for your spring, you're getting there. Every boat I've owned behaved a little differently (now on number 5, yea, I'm nuts).
post #48 of 48 Old 06-09-2013 Thread Starter
capecodda - I think that's basically what happened, yes. I'll keep playing around with it but I'm glad to be making some progress, it was getting a little frustrating ;-) Thanks for all the suggestions.
brianc is offline
docking line snubbers rmeador Gear & Maintenance 11 08-26-2011 01:51 PM
What is a spring line, and how do I tie it? TonyInNewportOregon Learning to Sail 8 02-04-2009 05:56 PM
Spring has finally sprung (again) / Spring Commission Check-Off list NewsReader Mass Bay Sailors 0 04-22-2007 05:15 PM
Shorter Single Line Reef Line dnseal Gear & Maintenance 6 11-26-2006 05:58 PM
TODAY: United Divers Spring Sale 2006 (Spring Is Here and it's time NewsReader Mass Bay Sailors 0 05-20-2006 11:15 AM
