Celebrity 20ft Fiberglass hull 1977. - SailNet Community
post #1 of 10 Old 06-05-2013 Thread Starter
Hi Folks. I have just purchased a 1977 Celebrity 20 Fiberglass hull sailboat. Yep its in need of "woodwork". There are four cross ribs that support the slats allowing a "drier" sailboat when sailing. These ribs have rotted.
Question. Are they specific type ribs or can they be generic and found elsewhere. If not I will try to remove from the boat inside bottom and replicate myself.
Question. How is the wood bonded/glued to the fiberglass inside bottom. Any suggestions would be wonderful...Steve
shumphries is offline
post #2 of 10 Old 06-05-2013
One of None
deniseO30's Avatar
Re: Celebrity 20ft Fiberglass hull 1977.
Were they exposed wood? or "encapsulated" ? in which case they would be called "timbers or stringers" some people call them ribs also. Anyway.. the easist way to make new is by ripping strips of wood that are the width + about 1/2" and about a 1/8-1/4 inch thick. you will need enough of this to make the height of the originals . You can flex bend the first 2 or 3 and use epoxy to glue them but with wax paper between the 1st strip. Use sticks clamps and boards across the hull to hold the strips in place until the epoxy cures. then you can continue in place or take them out and "build" more strips on the inside of the curve. Another way is to steam bend white oak, and force the bend down on the inside and like above use whatever you can to hold them in place. Use 3m 5200 if you use oak.. mahogany cherry, walnut, cypress, will stick with epoxy.
In all cases the boat hull is your "form" you will have to come up with ways to bend or make bent ribs to retore it.
My last project!
deniseO30 is offline
post #3 of 10 Old 06-05-2013 Thread Starter
Whoaa Denise I have a boat builder on the line !!!..
Thanks so much for the detailed response, I will inwardly digest your advice and take action !..if I am capable..
Denise, one out of the five was infact 'encapsulated", so it appears a long time ago someone else had problems.
Maybe there are professionals around that can do this part of the project for me !...Regards and thanks so much,
Steve J. Humphries
post #4 of 10 Old 06-05-2013
One of None
deniseO30's Avatar
hee hee thanks.. I've studied boats most of my life. Pay a pro to to fix a 1977 boat? It's really not all that difficult for a DIY. Photos of your project would help.
My last project!
post #5 of 10 Old 06-05-2013 Thread Starter
Thanks so much Denise, I will take some detailed pics tomorrow and send them to you, (this address)..I am way out of my "depth" in this subject, as I fly aircraft for a living ...
Steve ..
post #6 of 10 Old 06-06-2013
One of None
deniseO30's Avatar
What most of us do Steve, is put photos in an online sever. I use photobucket, then copy and paste the direct link to a photo by using the photo insert feature in the page icons.
Sounds like you have "rotted stringers" Not an easy fix on a big boat but on yours.. should be easy enough.
My last project!
post #7 of 10 Old 06-06-2013 Thread Starter
Hi Denise, I am fearless about this project !!
Its raining here today in Raleigh and I leave tomorrow for a weeks trip so I will take pics then and post as you suggest.
Thanks so much for communicating. Steve
post #8 of 10 Old 06-06-2013
krisscross's Avatar
Check out this link about Celebrity class boats: Celebrity Class sailboats - SailboatOwners.com
Good luck with the project. These boats are well worth restoring.
Plato
krisscross is offline
post #9 of 10 Old 06-06-2013
S/V Lilo, Islander 32
I'll agree with Denise on the "It's not that hard to DIY" comment. Things like this used to scare me to, until I started doing them. It's really not that hard, and if you DO mess it up, it's not that hard to tear it out and do it again. Even if it takes a few tries to get it right, it's still cheaper then hiring it done and the feeling of accomplishment will be well worth the time. Every time you show someone and tell them what you did, you'll feel much better if you did it yourself
Add your location to your profile, and perhaps you'll even get lucky enough to find someone experienced and local willing to come by and give some pointers or lend a hand. It's been known to happen around here
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #10 of 10 Old 06-06-2013
One of None
deniseO30's Avatar
Well Steve here's what you be missing if you don't get work! LOL
My last project!
Drilling Hole in Fiberglass Hull sailak Gear & Maintenance 16 03-17-2011 10:37 AM
Painting a fiberglass hull ? ebs675 Gear & Maintenance 10 07-11-2010 09:15 PM
How long will my fiberglass hull last? Edo Kazumichi Gear & Maintenance 27 05-13-2010 03:50 PM
Steel or fiberglass hull bjslife Living Aboard 10 11-09-2009 09:59 AM
fiberglass hull lifespan el Boat Review and Purchase Forum 2 12-30-2001 05:37 PM
