Removing old boat name decal - SailNet Community
 2Likes
  • 2 Post By sailak
post #1 of 8 Old 06-10-2013 Thread Starter
Crealock 37
sailak's Avatar
Dock
We did ours today and it turned out to be an easy job, although a bit time consuming.
First I used a heat-gun to peel the old lettering off which of course leaves glue residue behind. Next was "Professional Strength" aerosol Goof-off. Spray on rag and dab on to wet glue, let set a moment and use scraper to take glue off. Spray on rag to wipe off any remnants and Voila! old lettering is gone.
Was able to get the old names off and apply new names to both sides in one easy day.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #2 of 8 Old 06-10-2013
Re: Removing old boat name decal
Right on... does the new name 'hide' the shadow of the old OK??
Faster is offline
post #3 of 8 Old 06-10-2013 Thread Starter
Crealock 37
sailak's Avatar
Dock
We moved the new name forward so no it doesn't cover.
After getting the glue off I did a quickie touch with a Meguirs product. Don't remember the name but its between a cleaner wax and a polishing compound. It pretty much evened things out so there is only a faint shadow depending on lighting.
I'll post a pic when I get home.
Dale
S/V Elnora
sailak is offline
post #4 of 8 Old 06-10-2013
chucklesR's Avatar
I had to sand from 600 grit upwards to 1000 to get the shadow off, then finished with compound.
Haven't put the new name on yet, wax will be after that.
chucklesR is offline
post #5 of 8 Old 06-10-2013
kenr74's Avatar
Thanks for posting this. I was dreading doing mine. Now I am encouraged to give it a shot this week.
kenr74 is offline
post #6 of 8 Old 06-13-2013 Thread Starter
Crealock 37
sailak's Avatar
Dock
Here's a before and after shot of the boatname:
There is a bit of a shadow of the old name/hailing port depending on the lighting angle, but you have to look for it to see it. I plan to haul for bottom paint next spring, will compound and wax the topsides then and probably remove the last trace of Permagrin.
Kenr74, how's your project going?
Faster and dvuyxx like this.
Dale
S/V Elnora
sailak is offline
post #7 of 8 Old 06-13-2013
s/v Tiger Lily
dvuyxx's Avatar
I think that you will find time will also even out the shadow of the old vinyl especially white/off-white. For people that are hesitant to use a heat gun (me) ... a hair dryer usually softens up the vinyl enough to peel it up slowly or scrape with a sharp plastic scrape.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #8 of 8 Old 06-22-2013
Learning a bit every day
FinallySailing's Avatar
I've come across eraser wheels or pinstripe removers in an automobile accessory shop. Different people swear on different manufacturers, like 3M or TEX. They are basically giant rubber erasers that fit on a drill. As long as they are used at relatively low rpm they seem to be very good to remove vinyl decals from cars. Has anybody used them on their boat ?
https://www.youtube.com/watch?v=HHKN5_UfDik
FinallySailing is offline
How to removie name decal - and new name questions? aimcat General Discussion (sailing related) 25 09-16-2011 12:22 PM
US Recreational Vessel Decal coyemory General Discussion (sailing related) 15 07-23-2010 09:14 PM
Decal removal zz4gta Gear & Maintenance 16 03-26-2008 05:27 PM
removing painted boat name maureena5 Gear & Maintenance 1 02-20-2001 07:08 AM
Decal Removal TSC Gear & Maintenance 4 02-16-2001 05:55 PM
