Oversize furler - SailNet Community
post #1 of 3 Old 06-11-2013 Thread Starter
Walter H
Oversize furler
I and the crew (kids) are ready to move up to a furling system on our Pearson 26OD. I have the chance to purchase a Selden Furlex 300s for a reasonable price. The 300s is spec'd for boats 30 to 45ft. Recognizing I would have to upgrade the forestay are their any other reasons to not use the
oversized 300s?
Thanks
wahickman is offline
post #2 of 3 Old 06-11-2013
Re: Oversize furler
Furlex usually comes with a new forestay in any case - or is it used? Will the drum fit OK vis a vis your pulpit arrangement? It may look odd with such an oversized drum.
btw there's someone else here on SN that might be looking for a few feet of Furlex extrusion pieces..
Faster is offline
post #3 of 3 Old 06-11-2013
overbored's Avatar
Re: Oversize furler
you could use a 300 but the foil will be a bit large for the 26 and the clevis pin size may be to big for the stem and mast fittings. it may require a bigger diameter luff tape on the sail. better to get the one designed for you boat you will spend the difference in all the hardware changes needed and it will not work as well as it should.
"GOLD RUSH" PRINDLE 16
overbored is offline
Which Furler? sdinger General Discussion (sailing related) 7 03-09-2012 07:50 PM
O'Day 22 furler poster General Discussion (sailing related) 11 04-06-2011 10:14 PM
rolling furler QuickMick Gear & Maintenance 2 04-01-2010 10:37 AM
A Furler? jetdrvr393 Gear & Maintenance 6 11-10-2009 08:56 PM
New Jib Furler sailr4 Gear & Maintenance 0 10-23-2002 12:46 PM
