Mounting Rope Clutches - SailNet Community
 2Likes
  • 2 Post By jimgo
post #1 of 6 Old 06-14-2013 Thread Starter
I purchased two Spinlock XAS Double Rope Clutches on e-bay and will be mounting them in the next few of days. It looks like there is a place for an O-ring to be placed around the mounting holes between the block and deck. Also tag on part says not to use caulking. Not sure what I should use. I will be mounting them in front of the cabin top winches far enough forward to clear the winch handle and centered on the RH side of the winch. Can you guys verify my thinking or provide additional information. Thanks.
H and E is offline
post #2 of 6 Old 06-14-2013
sailvayu's Avatar
Re: Mounting Rope Clutches
Orings do work well, I always use a bit of sealant as well just in case just be careful not to use too much, a little dab will do ya.
Capt. Wayne Canning, AMS
sailvayu is offline
post #3 of 6 Old 06-14-2013
Asleep at the wheel
jimgo's Avatar
Butyl tape?
SHNOOL and rugosa like this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 6 Old 06-14-2013
4KSB driver.
SHNOOL's Avatar
Dock
I second Butyl tape... but I should head my own recommendations... like a lemming, I used 4200 on my cabintop cams, (which is fine), but I had a nice roll of that butyl tape I've used for a bunch of other things already (purchased from a member from here)... and honestly I should have used it instead.
The XAS clutches were on my long term wish list... I'd love to see a picture once you get them in.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
post #5 of 6 Old 06-14-2013
I just installed some XAS's a few weeks ago with butyl tape (from MaineSail). One thing I've found - when you make the cone of butyl around the base of the bolt (per MaineSails' awesome instructions) make sure you don't put so much butyl on that it squeezes down onto any threads that the tightening nut will need. Butyl does not flow easily, so if you tighten a nut over butyl the nut will seize on you. I've sheered off bolts that had butyl on the threads..
Reefpoints is offline
post #6 of 6 Old 06-14-2013
I don't discuss my member
zz4gta's Avatar
butyl tape, 4200, or O-rings all work. Chances are you'll need to remove them at some point, so O-ring or butyl is your best bet.
Merit 25 # 764 "Audrey"
zz4gta is offline
Shopping for rope clutches... MedSailor Gear & Maintenance 13 03-29-2013 07:27 PM
Rope Clutches, go small or big??? NewportNewbie General Discussion (sailing related) 14 03-29-2013 03:27 AM
rope clutches americanfrog Gear & Maintenance 11 09-07-2012 01:25 PM
Garhauer Rope Clutches rhr1956 Gear & Maintenance 8 01-25-2012 11:24 PM
Rope clutches ??? frankwittosch Gear & Maintenance 4 03-28-2001 12:45 PM
