What do you have for a cannon? - Page 2 - SailNet Community
 19Likes
post #11 of 63 Old 06-17-2013
Dog Ship's Avatar
Re: What do you have for a cannon?
26.5mm? That's 10 inches. You must meen 2.65mm which is 1".
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #12 of 63 Old 06-17-2013
Selkie60's Avatar
My deck gun: BIG-BANG Cannons Conestoga Company
Capt Chuck
S/V Selkie
Selkie60 is offline
post #13 of 63 Old 06-17-2013
bristol299bob's Avatar
I've seen a nice cannon made from a prop coupling.
The dude poured in black powder, and dropped a golf ball in. Stuck the fuse in through the set screw hole. Used a sandbag to adjust elevation and windage. He would shoot it out over the bay.
It was great fun.
to watch.
from a distance :-)
davidpm likes this.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #14 of 63 Old 06-17-2013
Over Hill Sailing Club
smurphny's Avatar
We used to have "Bangsite" cannons when we were kids. They made a pretty loud noise. Sounds like the same principle.
smurphny is offline
post #15 of 63 Old 06-17-2013
krisscross's Avatar
My friend, you need to study the metric system a bit more
I think you are confusing cm and mm.
mm to inches - millimeters conversion
26.5mm = 1 and 3⁄64"
They make great inserts that allow to shoot 12 gauge flares in these pistols. I make 12 ga blanks using my shotgun reloading press.
Plato
krisscross is offline
post #16 of 63 Old 06-17-2013
caneyln's Avatar
i have found a Coronado 25 that is completely stripped down, supposedly all the parts are "in the box". I am considering buying it and restoring it but i have been unable to find the hull id. Can anyone advise me where i might look to find it?
caneyln is offline
post #17 of 63 Old 06-17-2013
GeorgeB's Avatar
Kriss, 26.5mm is an odd caliber for a flare launcher. Is it war (or East Block) surplus? I own a 25mm launcher and flares for that (especially the longer duration parachutes) can be hard to find. I have an aluminum tube insert for mine in order to launch the more common 12ga flares. Even with a WWII surplus brass launcher, I’d be hesitant to use a more energetic propellant like smokeless or black powder. The ATF had an interesting article reporting on the dangers of using a 12ga insert to fire shotgun shells. The rest of the “gun” is pot metal and was prone to exploding into shrapnel when firing a shotgun round. Our club uses 12ga black powder signal rounds for race committee. They fire a plastic wad, which is plenty dangerous on its own. As for larger caliber ordnance, our club has a pair of fixed mount signal cannon flanking the flagpole, which we use ceremonially at noontime on Memorial Day and Fourth of July. Across from us is Coast Guard Island and they do a 21 gun salute with their signal cannon. At night, after the fireworks are finished, we hear a lot of gunfire coming from the Oakland neighborhoods. When the Lady Washington or Hawaiian Chieftain are down for the Master Mariners, we will fire a “broadside” as they pass the race dock. They in turn, respond with a broadside of their own.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #18 of 63 Old 06-17-2013
krisscross's Avatar
Some of those older boats did not have a hull ID numbers.
Plato
post #19 of 63 Old 06-17-2013
krisscross's Avatar
Originally Posted by GeorgeB View Post
Kriss, 26.5mm is an odd caliber for a flare launcher. Is it war (or East Block) surplus? I own a 25mm launcher and flares for that (especially the longer duration parachutes) can be hard to find. I have an aluminum tube insert for mine in order to launch the more common 12ga flares. Even with a WWII surplus brass launcher, Id be hesitant to use a more energetic propellant like smokeless or black powder. The ATF had an interesting article reporting on the dangers of using a 12ga insert to fire shotgun shells. The rest of the gun is pot metal and was prone to exploding into shrapnel when firing a shotgun round.
Yes, that is a surplus East Block caliber (my pistol is Polish and it is very well made, to military specs with proper steel barrel and locking mechanism. The inserts are not made to fire regular 12 ga rounds (chamber is shorter). But they are perfectly safe to fire our 12 ga flares - have done it many times with expired flares. These pistols are not built for firing 12 ga shot shells UNDER ANY CIRCUMSTANCES as the locking mechanism is too weak for that! I make 12 ga blanks using a small charge of regular propellant and a full size wad to hold it in place. I have done it for years without affecting the pistol's integrity.
Plato
post #20 of 63 Old 06-17-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Yep! Lotsa 26.5mm stuff here, and while most is E block; some even made in Germany and Austria. Mines Czech. Very rough and simple....soldier proof.
I am considering setting my 75mm "mortar" ( don;t worry... BP only, fuse lit and only for signals and marking! ) on the foredeck and launching a few pyrothechnics. While it was made for launching soup can "marking" rounds", it easily does double duty sending up commercial 3" 'mortar' displays.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
Signal Cannon pogosmoke General Discussion (sailing related) 6 11-11-2011 03:40 PM
cannon blast bubb2 General Discussion (sailing related) 2 03-11-2004 01:49 PM
