Three kinds of sailors - SailNet Community
 21Likes
post #1 of 28 Old 06-17-2013 Thread Starter
You know the saying, those that have run aground, those that will run aground and those that lie about it. I joined the first group this weekend, with about a dozen witnesses, so I had no choice but to take the heat.
We were heading back to the slip, but couldn't get through the bridge just outside the marina due to a accident. Someone had driven their car into one of the crossing gates and broken it, so thy couldn't lift the bridge until it was dealt with. We waited, and waited. And waited. All the while the tide was going out. When we finally got through, after an hour, it was REALLY close to low tide. I cut the last corner from the channel to the marina a little too much and there we were, with our keel stuck in the mud. Luckily we were going slowly, and it was a very soft grounding, so no damage. Our dockmates organized a couple of dinghies to help get us off, but we were able to heel the boat over enough to back out into the channel before we suffered the indignity of a tow. Attempt number two went much more smoothly and a few minutes later we were sitting with everyone trying to save some face. Then it came to me. We didn't run agound, we were simply doing a little charting of our own. I know right where that channel is now!
tsell is offline
post #2 of 28 Old 06-17-2013
Over Hill Sailing Club
smurphny's Avatar
Re: Three kinds of sailors
I ran aground recently in a spot I have been using for years that has shoaled up due to Hurricane Sandy. I was inching along and was able back right off but it still qualified as a grounding. Anyone trying to get up into Horsehoe Cove, just south of Sandy Hook, BEWARE. There is around 3' of water where there used to be 14'.
chef2sail likes this.
smurphny is offline
post #3 of 28 Old 06-18-2013
bigdogandy's Avatar
Dock
[QUOTE=tsell;1045314]You know the saying, those that have run aground, those that will run aground and those that lie about it. ......QUOTE]
I thought the three kinds of sailors were those who could count and those who couldn't?
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #4 of 28 Old 06-18-2013
Tundra Down
downeast450's Avatar
Yup! I am all three!
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #5 of 28 Old 06-18-2013 Thread Starter
[quote=bigdogandy;1045449]
Did you know that 4 out of every 3 people have trouble with fractions?
smackdaddy, zeehag and G20 like this.
tsell is offline
post #6 of 28 Old 06-18-2013
I have. It happens to everyone unless you stick to marinas and the middle of the channel.
Not all coves and anchorages are fully chartered. There can be shoaling, even if they were. To keep some seamanship in the act of grounding, one should only poke around these areas when you know there is an incoming tide to bail you out, proceed slowly enough that you don't go hard aground or have other backup resources (like your buddies with dinghies).
It's all fine, as long as you can use the boat again.
Personally, I think the worst is grounding overnight on the mooring during low tide and waking to find everyone else clocked into the wind but you. Tides that day were a foot lower than normal. Um.... had a friend do that.
Jeanneau 54DS
Minnewaska is offline
post #7 of 28 Old 06-18-2013
blutoyz's Avatar
Already posted mine....
blutoyz is offline
post #8 of 28 Old 06-18-2013
DrB
Never run aground
while at the helm.
Wife did for about 10seconds,then I took over and powered it back out of the mud and off we went.
Was on another boat that ran aground hard ( 6+ kts) on rocks. Cracked the bilge/keel joint. Skipper wanted to cut across between two marks on our established course to save about 15 minutes. He asked me, who was near the chart table at the time, to see if we could. I did a quick estimate of where we I thought we were by looking out of the companionway and the course bearing and said I thought so, but wasn't 100% sure of our exact position and the Navigator should confirm our position and such. We traded positions and he confirms that we are good and we change course. 2 minutes later we were hard aground.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #9 of 28 Old 06-18-2013
utchuckd's Avatar
Donnie Harris
1980 O'Day 23
utchuckd is offline
The Following User Says Thank You to utchuckd For This Useful Post:
fryewe (06-18-2013)
post #10 of 28 Old 06-18-2013
krisscross's Avatar
I sail on the shallow and always changing Pamlico Sound and I always keep my swing keel down just a bit. When I do run aground (happens quite often), I just lift the keel and off I go.
Plato
krisscross is offline
All kinds of sailing sailmax Introduce Yourself 0 05-27-2011 02:41 PM
2 kinds of sailors... Joesaila General Discussion (sailing related) 18 06-29-2009 05:47 PM
kinds of maritime cruising Karalia Cruising & Liveaboard Forum 11 09-04-2007 10:18 PM
