using a trolling motor for power - Page 3 - SailNet Community
 2Likes
post #21 of 28 Old 06-27-2013
Re: using a trolling motor for power
Originally Posted by avenger79 View Post
perfect. yeah I just need it to get away from and back to the dock. I have sailed out and in before but these are new to me lakes. would be small ish lakes.
I may still break down and buy an OB but troller is less $$ and easier on upkeep
I had a 45 lb thrust electric motor on my fishing boat. As described above it would probably be OK in light wind.
However, by the time you buy the motor and a big battery you are probably looking at about 70 or so pounds and need a way to keep the battery charged.
I also had a 2 HP Honda 4 stroke outboard on another boat. It weighed about 27 lbs and would have a whole lot more thrust than a trolling motor and it won't run out of "juice". The integral tank would last us all day trolling and running to different fishing spots. We used to take an extra pint of gas with us but never had to use it. Maintenance was to change the oil once a year and drain the carb between uses, pretty simple. I sold it, in perfect condition, for $400 after running it very hard for 28 years with no problems.
Paul T
dabnis is offline
post #22 of 28 Old 07-24-2013
We use 55 lb. thrust on a 16' Precision, roll-up solar charger keeps it charged.
It can go pretty far in a calm, and can fight winds for short distances (I.e. getting upwind to mooring).
I've sailed a heavier 19' boat in salt water that had a 40 lb. thrust electric outboard,
and it works surprisingly well, even against current.
I've never had problems with range or power -- electric is
clean, cheap and convenient.
Schecky is offline
post #23 of 28 Old 07-25-2013
Smile Re: using a trolling motor for power
I use a 40 lbs thrust trolling motor to push my San Juan 23 to and from the dock with great results. I have a battery bank of 4 deep cycle batteries and they last all weekend with one charge. I like being able to get in the boat and move it to a slip for rigging without worring if a gas motor will start. The boat weighs 3000 lbs and moves with no problems. I also fish with the same motor when there is no wind.
Griffinroydonald is offline
post #24 of 28 Old 07-26-2013
I just bought a 16 foot Topper Sport dinghy, and it came with a Minn Kota trolling motor with 50 lbs of thrust. It is a real hassle lugging the damn battery around, but since I just started sailing, it has already saved me a few times as I'm drifting towards shore and can't seem to get started...
The aim here is to use it just to get in and out of the marina. Yesterday was my first time I didn't use it other than for that reason.
I put the motor and batter on a little hand truck to get it around.
Plus, I do like that it is so quiet as I motor out. Adds to the overall peaceful setting...
Mike
mike21070 is offline
post #25 of 28 Old 07-26-2013
I use a little 30 pound thrust trolling motor on several small boats. I've traveled several miles with two jet ski batteries. I use one battery when I'm outbound and when it runs down, I know it's time to switch batteries and head home. For my inflatable I use a 2.5 hp Lehr propane outboard. It replaced a 2 hp Suzuki that would gum up every time it sat for a month or more without running. I got tired of cleaning the carb.
hopcar is offline
post #26 of 28 Old 07-26-2013
Bring On The Wind
CatMan22's Avatar
I owned a Catalina 22 that came with a cantankerous Ted Williams 7.5 that would run fine sometimes and leave me stranded other times. I had an old Lark outboard I traded to a neighbor for a bow mount Minn Kota 72 that I took apart and fitted the transom mount off an old Johnson 4.5 I had in my garage, it worked better than I expected. I sold the Catalina and kept the troller for a back to my current boat which has a Tohatsu 9.8. A month ago I bought my son his first sailboat, an American Fiberglass 16, that came with no motor and hooked the stroller up for him and it provides more than enough power to get him in and out of the dock and into a cove if the weather turns bad while on the water.
S/V CatManDeux
Catalina 22
"hark, now hear the sailors cry,
smell the sea, and feel the sky
let your soul & spirit fly, into the mystic..."
Van Morrison
CatMan22 is offline
post #27 of 28 Old 09-02-2013
Just adding my experience for future thread readers:
I have a Seaward 17 with a older Minn Kota trolling motor (says 3hp on it, back when that was still the way to list it) I sail inland lakes. Basically it gets me in and out of the docks. As a trailer sailor and working stiff I have to take the days I can to sail, so unfortunately my stubbornness has bought me a few 4 mile trolling sessions. I would say electric is great, quiet, convenient, and if it is crowded and choppy you can maneuver like a pro with the rudder and a fully rotatable trolling motor. Almost parallel parking. That said, it does get overpowered by wind and sometimes those wake setter boats. Equally important putting in at a busy choppy ramp can be rough because it doesnt have enough power to get you in and out safely.
Also like others said a big deep cycle can get you back without wind but plan a few extra hours to your trip... Hot, slow, windless hours... At about 2mph or less
...after this first season I'm considering an old OB and keeping both. Trolling for regular use, gas if the wind dies or we have guests and a reservation somewhere
Eyerish is offline
post #28 of 28 Old 09-02-2013
manatee's Avatar
F.Y.I.
$10 Yuloh - Cheap introduction to "scientific sculling."
Duckworks - The Easy Go Yuloh - Part One
WOODENBOAT NZ Sculling and Yuloh Page Three
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you don’t."
~~Dylan Winter,
manatee is offline
trolling motor mcnabbstacy Gear & Maintenance 3 07-29-2012 12:14 PM
Trolling Motor Suitable for Dinghy Power? NCC320 General Discussion (sailing related) 9 03-23-2011 09:32 AM
Trolling motor power consumption? SteveON Gear & Maintenance 6 08-11-2010 02:15 PM
trolling motor generator dodgeboatguy Gear & Maintenance 3 07-19-2007 04:22 PM
trolling motor generator dodgeboatguy Gear & Maintenance 0 07-18-2007 11:24 PM
