yanmar idle speed - SailNet Community
 2Likes
  • 1 Post By PaulinVictoria
  • 1 Post By MSO sailor
post #1 of 9 Old 06-19-2013 Thread Starter
yanmar idle speed
My Yanmar 1GM is idling at 1000 RPM, so when i'm trying to berth it i'm running too fast! What should the idle speed be & how is it adjusted?
Thanks
MSO
MSO sailor is offline
post #2 of 9 Old 06-19-2013
yanmar idle speed
With out looking at the shop manual I'm not sure how to lower the idle speed. What I do is take the engine out of gear and coast to bleed off speed then as needed just pop it in and out of gear to maintain steerage
1982 Morgan 321
sebez is offline
post #3 of 9 Old 06-19-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: yanmar idle speed
I'm guessing you don't have the manual.
I have a manual for 1GM, 2GM, 3GM. It states idle speed is about 850-900rpm.
If you are able to lower it, try adjusting the control cable at the idle adjusting bolt to see if you can get the idle speed lower.
Or, as sebez said, go in and out of gear to keep from going too quickly.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #4 of 9 Old 06-19-2013
Daniel - Norsea 27
BTW, if you need a manual, try this. This is the one I'm talking about that I have.
http://j30.us/files/yanmar-manual.pdf
Daniel
1981 Nor'sea 27,
-Paul Carvel
post #5 of 9 Old 06-19-2013
Senior Slacker
SlowButSteady's Avatar
I usually put the engine on my boat (a Cal 2-27 with a 2gm20) in neutral about 100 to 150 feet from the slip and coast until I'm just about to turn into the slip. At that point I either give it a little blast in reverse (as I'm usually still going a tad too fast), or a little blast in forward (if I'm going too slow), and ghost into the slip. Idling all the way into the slip, as you seem to be finding, would be way too fast.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
Last edited by SlowButSteady; 06-19-2013 at 09:41 PM. Reason: Can't have any typos. Right Chrisncate????
SlowButSteady is offline
post #6 of 9 Old 06-19-2013 Thread Starter
My slip & dockage is very tight.I just don't have the room to be "coasting 100-150 ft" I just wanted to know how to lower the idle.I would like to get it down to about 800RPMs
MSO
post #7 of 9 Old 06-19-2013
Senior Slacker
MSO
The approach to my slip is fairly tight also. Coasting doesn't mean that one doesn't have steerage. Even at very slow speeds a sailboat will be going plenty fast enough to have steerage.
post #8 of 9 Old 06-20-2013
Remember you're a womble
PaulinVictoria's Avatar
As you look at the front of the engine, on the left is the throttle lever. On the front of that is a screw (should have a locking nut on it). Undo the locking nut, and then turn the idle adjuster screw anti-clockwise until you have the idle you like (should be between 850 and 900rpm). Make sure the engine is warmed up before making this adjustment. It's very simple. Remember to tighten the lock nut back up afterwards.
Seaduction likes this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #9 of 9 Old 06-20-2013 Thread Starter
Thank You!!
Jim
Yanmar 2QM15 Overheating at Idle... backcreeksailor Gear & Maintenance 35 08-16-2012 10:58 AM
Yanmar yms12 wont idle Domknotty Diesel 18 05-19-2012 12:05 PM
Forward idle speed Barquito Gear & Maintenance 7 12-01-2011 07:50 PM
Yanmar 3HM (27 hp) stalls won't idle when warm Alacrity36 Diesel 1 10-11-2010 07:36 PM
Idle speed and throttle position jaschrumpf Atomic 4 2 06-19-2008 08:56 PM
