Back stay boom supporter broke - now what? - Page 3 - SailNet Community
 1Likes
post #21 of 25 Old 06-20-2013
Re: Back stay boom supporter broke - now what?
Originally Posted by capttb View Post
Sorry, can't get past this part, how do you reef without pointing into the wind ?
Jeff beat me to it, but since you are asking.
My boat is a 38 feet boat with main sail area of 34 m2 (368 sq feet), inline spreaders, two line reef setup, lazy bag and a rigid vang.
The mast (or tack) reef line is attached to a ring in the sail and is led back to the cabin top winch. The clew ref line is a standard setup going to the opposite cabintop winch (alternate side's for each reef).
But this technique works on other boats also. We did this on a Hanse 470 (with swept spreaders and single line reef) a week ago while sailing upwind in a race (At one of the owners amazement - he wanted to head into the wind for reefing while racing)
We can do this at most point's of sail except DDW, you must not sail so deep that the sail will hang on the spreaders during the operation.
Here is the procedure.
  1. Put or keep the boat on a course where you can do the maneuver and have sufficient room/time to complete (preferably on starboard tack
  2. Tighten the topping lift (If you don't have a rigid vang)
  3. Ease the main sheet a little to take pressure off the sail.
  4. Ease the kicker so the boom have room to lift
  5. Slack the main halyard to preset mark (if no mark you must take it in increments - don't ease to much)
  6. Use the winch to haul in the tack (mast) reef line
  7. Use the winch to haul in the clew reef line
  8. (If you have single line reef only one line but more rope)
  9. You should not need to touch the halyard any more
  10. Sheet in
  11. Tighten kicker (if needed)
  12. Clear up all the lines
  13. Finished
My boat is tracking so good that i can do this singlehanded w/o any use of autopilot or engine, everything is done from the cockpit close to wheel and winches.
I prefer this method because
I get a more stable platform to work on than a boat bobbing on the waves
Don't loose much headway while doing it
knuterikt is offline
post #22 of 25 Old 06-21-2013
blutoyz's Avatar
Thanks for the great thread...I was out in a blow on Monday and the topping lift was a PIA to connect up to drop the main. I do believe one of these bookickers are on the short list now
blutoyz is offline
post #23 of 25 Old 06-21-2013
TakeFive's Avatar
A topping lift doesn't need to ever be disconnected. You just loosen it if you want your boom a little lower. That's why it's so much better than the pigtail off the backstay.
I'm not saying that a boomkicker isn't a good thing - just that your comment makes it sound like you may be misuing your topping lift.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #24 of 25 Old 06-21-2013
no longer reading SailNet
Alex W's Avatar
95% of the time a topping lift doesn't need to be adjusted.
If it is just longer than the leech and light enough it will do the job without adjustment. When you raise sail the leech will slightly lift the boom and detension the topping lift, letting it blow out of the way. When you lower the sail the boom will drop a couple of inches until the topping lift does it's just.
I only have an adjustable topping lift because the Salish Sea has a lot of light air and I will tension the topping lift to avoid closing the mainsail leech when sailing in very light winds. I adjust it about once every 10 sailing days.
Alex W is offline
post #25 of 25 Old 06-22-2013
blutoyz's Avatar
I have the pigtail off the backstay, it gets disconnected
blutoyz is offline
new stay broke dam smallboatlover General Discussion (sailing related) 5 10-19-2011 06:03 AM
Her Back is Broke! Cjflyer Seafarer 12 08-23-2010 07:11 PM
GIULIETTA's BROKE MY BOOM!!!!!!!! ouch!!!!! Giulietta General Discussion (sailing related) 66 03-29-2007 01:14 PM
