Winch covers? - Page 2 - SailNet Community
 2Likes
post #11 of 34 Old 06-20-2013
Re: Winch covers?
When I had black anodized Barients, I think the covers were definitely worthwhile... They could help prevent the winches from getting too hot, and thus inhibit the grease from liquefying...
Since I've switched to stainless Andersens, that's probably not as critical, but I continue to use them anyway, figure it can't hurt... I still imagine the possibility they keep the heat down is likely the primary benefit...
JonEisberg is offline
post #12 of 34 Old 06-20-2013
HANUMAN
RobGallagher's Avatar
Re: Winch covers?
Originally Posted by MastUndSchotbruch View Post
They don't have to be waterproof, just shed enough water so it does not get drenched inside on a regular basis. Sunbrella does this (ever sit under a sunbrella awning in the rain?)
Yea, I guess I have.
From what others are posting I guess maybe it could probably just might be one of those damned if you do, damned if you don't thingies.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is online now
post #13 of 34 Old 08-14-2013
Re: Winch covers?
What he said.
abrahamx is offline
post #14 of 34 Old 08-14-2013
Master Mariner
capta's Avatar
Re: Winch covers?
The PO of this boat advised me to always use the winch covers, stating that w/o them he had to rebuild the electric Lewmar 65s once a year. We do and it's been 3 years with no problems so we will continue to use them on all our winches.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #15 of 34 Old 08-14-2013
Crealock 37
sailak's Avatar
Dock
Re: Winch covers?
Here in Seward we get lots of coal dust and glacial silt. Winch covers probably help to keep some of that out of the innards of the wenches...and winches.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #16 of 34 Old 08-14-2013
Re: Winch covers?
My previous boat used to get shadowy streaks running down the gelcoat below the winches. I believe they were caused by minute amounts of oil and grease that was washed out of the winches. Also, if you sail in salt water and have taken apart winches that were not lubricated frequently, you may have seen salt caked into the winch grease. I believe sunbrella or similar winch covers helps prevent both these conditions.
Sailormon6 is online now
post #17 of 34 Old 08-14-2013
Re: Winch covers?
I think Sailak has the right of it.
I just disassembled one of my Barient 28ST's, and there was a shocking amount of sand/dust/grit in the works, and on the coaming beneath the winch base.
I suspect that the biggest benefit of the covers is to prevent so much of the dry stuff from blowing in/up/around the winches, although the ideas about reducing heat and water intrusion have some merit as well.
Andy
aelkin is offline
post #18 of 34 Old 08-14-2013
Master Mariner
capta's Avatar
Re: Winch covers?
I don't know about you, but we don't sail with the winch covers on.
Our Videos;
capta is online now
post #19 of 34 Old 08-14-2013
Bradhamlet's Avatar
Re: Winch covers?
We have four covered and one uncovered(never got around to replacing the missing one). The covered ones spin nicely the uncovered one sounds like sand has made it's way into it. It still works but takes more maintenace than the covered ones. So if you have them I would use them. my .02 cents worth.
Brad
Lancer 36
Bradhamlet is offline
The Following User Says Thank You to Bradhamlet For This Useful Post:
emcentar (08-14-2013)
post #20 of 34 Old 08-14-2013
Re: Winch covers?
Brad
Lancer 36
Nice direct and unbiased comparison. Your observation agrees exactly with what Don Casey says in one of his books (I think either This Old Boat or his canvas book): winch covers reduce the need for winch maintenance.
MastUndSchotbruch is offline
Winch covers--are they worth it? soulfinger Gear & Maintenance 21 03-22-2015 01:53 PM
Winch handle in winch glassdad General Discussion (sailing related) 19 05-11-2011 06:10 PM
Battery Covers wchevron Gear & Maintenance 2 04-29-2008 07:50 PM
Boat Covers eck News Feeds 0 10-09-2006 05:51 AM
Boat Covers Dan Dickison Her Sailnet Articles 0 08-05-2002 09:00 PM
