Gangplank Ideas? - SailNet Community
post #1 of 12 Old 06-21-2013 Thread Starter
Gangplank Ideas?
I just built a gangplank that turned out to be too heavy. I was wondering if anyone else had any ideas to make a cheap gangplank. I know I could probably use a 2x16 board, but I was trying for a little more class. I would like to make it out of aluminum but can't find any plans and not sure how strong to make it, and it be light before buying the material.
Any ideas?
Here is a picture of the one I made.
pyewackette is offline
post #2 of 12 Old 06-21-2013
Re: Gangplank Ideas?
The quick and easy way might be to buy a six foot aluminum ladder, then screw a piece of 1/4" plywood on top of it as the footing.
Plans for a gangplank...I kind of have to cringe at the thought. I mean, it is two rails, some crossmembers, and something to walk on, and if you need plans for that, you may be best off simply buying one. Like, the ladder plus something to lay on top of it. The ladder will be about the simplest, lightest, strongest piece of fabricated aluminum you can find for the job, and the best way to do it. Bolt two "cart" wheels on the dock end if you want it to roll instead of scrape as the gangway moves. The guys in Ace Hardware or any similar shop can set you up.
hellosailor is offline
post #3 of 12 Old 06-21-2013
travlin-easy's Avatar
I saw one in Florida that was on a 75' motor yacht that the owner purchased on Ebay. It was pretty simple, made of aluminum diamond grid, and had a fold-down rail on one side. It weighed about 50 pounds, and was about 6-feet long and 18 inches wide. He also had some glue-on strips that resembled course sandpaper that were about 12 inches X 1-inch and provided great traction when the gangplank was wet. He paid about $250 for it, which I thought was a great bargain.
Gary
travlin-easy is online now
post #4 of 12 Old 06-21-2013
Large Member
GMFL's Avatar
Try this, adjustable too.
PA210 10'-17' Aluminum Extension Plank
GMFL is offline
post #5 of 12 Old 06-21-2013 Thread Starter
Hey sorry the 'plans' comment. It was really about trying to figure out what the least of mount of structure would need to be built to hold a specified weight. You are right, the building it was easy, I just want to build it with the least amount of material.
The ladder/plywood is good.
However, I would question the ability of anyone in an Ace Hardware store to come up with anything that is practical. Ace Hardware stores are like 7-11 to grocery stores. But then again, some of the bigger home repair stores are manned with the same types of blethering idiots.
post #6 of 12 Old 06-21-2013 Thread Starter
Guess I need to reemphasize the 'cheap' part of my request.
post #7 of 12 Old 06-21-2013
poopdeckpappy's Avatar
Solvit Deluxe XL Telescoping Pet Ramp
Only 18lbs and supports 300lbs
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #8 of 12 Old 06-21-2013
You don't want to buy it, but go to a motorcycle shop and look at loading ramps.
desert rat is offline
post #9 of 12 Old 06-21-2013
Large Member
GMFL's Avatar
https://www.google.com/search?q=tras...63%3B800%3B536
GMFL is offline
post #10 of 12 Old 06-21-2013
manatee's Avatar
A good medical equipment supply company should be able to show you a number of styles & sizes of portable wheelchair ramps. Don't know your physical or financial constraints, but they should give you some ideas.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
Solent Stay Ideas-Possible hairbrained ideas Joel H. General Discussion (sailing related) 39 01-26-2013 07:09 PM
Talisman: Crossing the gangplank - my.hsj.org NewsReader News Feeds 0 01-25-2012 11:50 PM
Gangplank Marina - Washington, DC ArcherBowman There's This Place... 11 09-17-2010 09:52 PM
DIY Gangplank? corny Gear & Maintenance 4 06-22-2009 02:53 PM
