Acetone vs Interlux 202 - SailNet Community
post #1 of 11 Old 06-22-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
So, if acetone manages to shift some sort of hull sealant, is Interlux 202 also likely to shift it?
Acetone is a bit too volatile, it evaporates before you get a chance to wipe off what it's lifted so you have to go over it again and again and again without seemingly ever actually removing the goop (it mostly just gets spread around) , 202 has stabilisers to give you a chance to use a 2 rag clean so although it's a ton more expensive, I might actually use a ton less.
P.S. If I ever see anyone applying any sort of magic "never wax this again, miracle cure for a dull boat" type stuff to a hull, I am going to smack them upside the head and throw them in the sea. I have spent two 12 hour days trying to get this crap off my topsides, finally resorted to acetone this evening and it's started to shift it.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 11 Old 06-23-2013 Thread Starter
Re: Acetone vs Interlux 202
Well, the answer was a resounding no. Interlux 202 could not shift it in the slightest so I had to burn through a ton of acetone instead. Nice stuff to work with. Not.
Orange Crush
1974 C&C27 MkII
post #3 of 11 Old 06-23-2013
The auto paint supplies used to sell a solvent called Tumbler.. We used that for wipe/dewax prior to our top sides paint job...
These are all nasty products, hope you've got a respirator..
Faster is online now
post #4 of 11 Old 06-23-2013 Thread Starter
Nah, gloves and outdoors.
Orange Crush
1974 C&C27 MkII
post #5 of 11 Old 06-23-2013
Senior Moment Member
SloopJonB's Avatar
Huh? gluvs? wut are dey? (twitch, shuffle).
SloopJonB is offline
post #6 of 11 Old 06-23-2013 Thread Starter
I figure with the amount I drink and the crap I eat, a few chemicals aren't going to do much worse
Orange Crush
1974 C&C27 MkII
post #7 of 11 Old 06-24-2013
I don't discuss my member
zz4gta's Avatar
acetone is nasty stuff and stays in your system for a long time. I'd avoid prolonged exposure if posible.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #8 of 11 Old 06-24-2013
Acetone is not the best product or safest. I used to use MEK for prepping metal before it was outlawed (almost everywhere). I have no idea what it would do to plastics. REALLY nasty stuff. I will never use again.
Possibly....
Polyprep degreaser and dewaxer - P91003 | LawsonProducts.com
Funny; other forums recommend the interlux.
When i was in the auto refinishing business i never used acetone. I wouldn't think it would be the best choice.
benesailor is offline
post #9 of 11 Old 06-24-2013
s/v Tiger Lily
dvuyxx's Avatar
In 2005, the U. S. Environmental Protection Agency removed (MEK) from the list of hazardous air pollutants (HAPs). After technical review and consideration of public comments, EPA concluded that potential exposures to butanone emitted from industrial processes may not reasonably be anticipated to cause human health or environmental problems. Emissions of butanone will continue to be regulated as a volatile organic compound because of its contribution to the formation of tropospheric (ground-level) ozone.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #10 of 11 Old 06-24-2013 Thread Starter
The bottom line is that in this particular case acetone worked, 202 didn't. I'm sure 202 is great for stripping off wax and some other stuff, just not this stuff.
Orange Crush
1974 C&C27 MkII
Bio-Solv - acetone replacement 14432 Gear & Maintenance 3 01-15-2010 03:22 PM
Acetone use drynoc Gear & Maintenance 14 02-08-2009 12:07 AM
Acetone or Mineral spirits? Finallybuyingaboat Gear & Maintenance 11 04-30-2008 01:52 PM
Drying Wet Deck Core with Acetone saurav16 Gear & Maintenance 11 10-08-2007 01:06 PM
202 Solvent vs. Acetone Timm40 Gear & Maintenance 8 03-01-2004 02:44 PM
